1Back to top Go down   Loctite type Empty Loctite type Wed Apr 04, 2012 12:17 am
Halo
Halo
What type of loctite do I use to stop the final drive outer racer from spinning in the case please?
84 K100RS 0014803
93 FZR1000 EXUP
2Back to top Go down   Loctite type Empty Re: Loctite type Wed Apr 04, 2012 1:35 am
pjjms
638 retaining compound should be ok, but please take advice from your stockest. Selection is dependant on how loose the bearing is, temperature and load. They should have a quick refrence leaflet for selecting the correct product.
Key thing is to get things clean and dry. You will need to clean both surfaces with a solvent like brakekleen or the retaining compount will not work.
3Back to top Go down   Loctite type Empty Re: Loctite type Wed Apr 04, 2012 2:07 am
Halo
Halo
Thanks pjjms
84 K100RS 0014803
93 FZR1000 EXUP
Dennis
Dennis
Some of the Loctite numbers I see quoted here at times seem to (maybe) differ slightly from those in Oz. You need to use a retaining compound and prep the surfaces using a Loctite Primer product. Be mindful that the bearing has quite some surface area so the Loctite will have no problem preventing the raceway "creep". I suggest you select a low strength grade. Heat will be required on the FD housing if/when you finally need to removed the bearing. Hope this helps, Dennis.
