1Back to top Go down   The light control (Right side) Empty The light control (Right side) Tue Apr 03, 2012 4:39 am
komandoalicante
komandoalicante
Here's the light control (Right side) on the back we will remove the piece that holds the wires, removing the screw marked with arrow
The light control (Right side) 001
Removing this screw allows us to pull the turn signal switch to remove
The light control (Right side) 002
Now let's remove the screw holding the button turn signal cancellation. You have to pay special attention, because in this hole there's the light switch screw marked with the black arrow, note that the cancellation is in a vertical plane while the light is in a horizontal plane.
The light control (Right side) 003
This is the position of the screwdriver to remove the screw-flash cancel button
The light control (Right side) 004
When you start to loosen the screw, you must be careful to hold the button, so do not jump the ground and slip
The light control (Right side) 005
In the button you can see the pier and slip switch
The light control (Right side) 006
The light control (Right side) 007
And what is your position.
The light control (Right side) 008
Now you can see the screw on the remote control of lights, as I said this is in a horizontal plane.
The light control (Right side) 009
The light control (Right side) 010
Never remove the screw holding the plastic before.
The light control (Right side) 011
The light control (Right side) 012
Carefully remove the slide it is below the pier and the steel ball.
The light control (Right side) 014
The steel ball is often left in the hole, look carefully.
The light control (Right side) 015
When you remove these screws has been very careful with contact steel ball and spring brass
The light control (Right side) 016
The light control (Right side) 017
Now carefully lift the white slide
The light control (Right side) 018
You can see the spring contact and the ball
The light control (Right side) 019
The light control (Right side) 020
Your turn to clean
The light control (Right side) 021
Dismantle the emergency stop
The light control (Right side) 022
With a small screwdriver you a little leverage
The light control (Right side) 023
Remember holding work when removing red cables, since the part which is also very sensitive
The light control (Right side) 024
The light control (Right side) 025
Do not miss these two springs
The light control (Right side) 026
The light control (Right side) 027
As the cable sheath is too damaged, you can put some heat shrink, we need to remove the connector
The light control (Right side) 031
With a small screwdriver do a bit of pressure to bend a small tabs that keep out the contact back. Look at the following two photos
The light control (Right side) 032
By pressing the tabs have collapsed, allowing passage through the plastic connector
The light control (Right side) 033
Now we have to open the tabs, so that when we insert the contacts into the connector, are set
The light control (Right side) 034
With a little patience is out the connector.
The light control (Right side) 038
This is the reason for removing the connector
The light control (Right side) 039
The light control (Right side) 042
Apply heat
The light control (Right side) 043
The light control (Right side) 044
Cleaning and lubrication
The light control (Right side) 045
That's how the contacts were dirty
The light control (Right side) 046
I had a problem with the intermittent contact
The light control (Right side) 047
We pulled the pin
The light control (Right side) 048
The dirt was widespread, clean and assemble
The light control (Right side) 050
More cleaning
The light control (Right side) 052
We cleaned
The light control (Right side) 053
Clean and lubricated (Vaseline)
The light control (Right side) 055
Clean and grease
The light control (Right side) 056
The light control (Right side) 058
The light control (Right side) 059
This part is very delicate, the contact is easily damaged, and if you lose your way will cost you to make it work well so arming you patience.
The light control (Right side) 060
All clean and ready for lubricating oil on
The light control (Right side) 061
Already lubricated and cleaned contact
The light control (Right side) 062
You must be very careful when mounting the slide with the contact and spring, spring ball and the ball, holding the whole loosely and put the screw.
The light control (Right side) 063
The ball is under the dock
The light control (Right side) 064
We present the slide while holding the whole
The light control (Right side) 065
And finally look with screw
The light control (Right side) 066
EThis is the smallest screw, if you put another in his place, you can remove the front and not look good.
The light control (Right side) 067
We will mount the flash cancel button, you can now take advantage of and clean up a little, well, you can carefully review the outline of the symbol, with a permanent marker.
The light control (Right side) 068
The light control (Right side) 069
Hold it while you put the screw
The light control (Right side) 070
Remember that in this there is the sliding screw the lights but on another level.
The light control (Right side) 071
And finally put in place the right turn signal button and screwed.
The light control (Right side) 072
The light control (Right side) 073
this. this, this is all folks.
Regards
SAK3 and komandoalicante is the same person
In March we made a International meeting  KEDADA ALICANTE of BMW motorcycle K in  Spain.
The last meeeting  March 2020
https://youtu.be/hfqxlGeEVsY
https://picasaweb.google.com/100417997445250027277
2Back to top Go down   The light control (Right side) Empty Re: The light control (Right side) Tue Apr 03, 2012 6:18 am
mike d
Excellent, informative post - Thanks.
Mike
3Back to top Go down   The light control (Right side) Empty Re: The light control (Right side) Tue Apr 03, 2012 10:02 am
beanoldboy
beanoldboy
Thank you , this is a valuable and informative piece. It will find its way into the collection of knowledge i am certain, very good photography also, please keep it coming.
http://www.airware.com.au
4Back to top Go down   The light control (Right side) Empty Re: The light control (Right side) Tue Apr 03, 2012 10:57 am
greecek100rt
greecek100rt
nice job
use a dremel with a small brush (brass) to renew the plastic buttons
The light control (Right side) Dsc03710
