1Back to top Go down   Clutch push rod Empty Clutch push rod Fri Jun 22, 2012 2:54 am
captaink
captaink
Morning people,
I'm in the process of removing gearbox from the engine to replace mail seal, I have hit a small snag, is it imperative for the clutch push rod to be removed before unbolting from main engine. I've seen the German clip a hundred times, and mine just doesn't want to move. I have read somewhere here that its possible to have a K75 rod in a K100. Can I just remove gear box without taking the out rod?
captaink
1989 k 100rs
2Back to top Go down   Clutch push rod Empty Re: Clutch push rod Fri Jun 22, 2012 3:05 am
nino
Yes, I removed gearbox without removing clutch pushrod. Just maintain engine and gearbox at same level during operation. Change the seal on gearbox side too.
Regards
3Back to top Go down   Clutch push rod Empty Re: Clutch push rod Fri Jun 22, 2012 3:58 am
captaink
captaink
Thanks nino, will do Smile
1989 k 100rs
