1Back to top Go down   Breather hose Empty Breather hose Wed Feb 22, 2012 9:17 am
Brickee
Brickee
While getting into the winter maintenance projects, I came across this breather tube coming out of the timing chain cover. Should it be plugged as I found it, unplugged or routed somewhere? Thanks for any info.
Breather hose Breath10
2Back to top Go down   Breather hose Empty Re: Breather hose Wed Feb 22, 2012 9:45 am
whhoon
whhoon
It needs to be plugged, it used to be the fuel tank vent. Was kind of a bad idea I guess. You do need to check that your tank vent hose is hooked to the tank or you have the cup in place. Hope that helps
3Back to top Go down   Breather hose Empty Re: Breather hose Wed Feb 22, 2012 10:24 am
Brickee
Brickee
Thanks whhoon, that does help. I replaced the vent hoses last winter.
