1 Code 7 - ABS 1.5 Tue Nov 20, 2012 4:18 pm
George R
Hi - Have just bought myself another K75 ( Last one written off by white van man) but on investigating to find out why there were no ABS lamps lit, found the small blue ABS Relay in the bottom of the Relay box and the ABS Brain disconnected. Replaced those bits, then ign on, ABS and fault light flashing in unison. Got up past initialitation speed but no change. Connect up analogue meter to 3 pin connector and it reported Code 7 - Brain dead. Have sourced a working ABS Brain - what checks on the rest of the system should I make and instructions, before connecting the replacement ?
Not had anything to do with ABS before - any help much appeciated
Thanks in advance
Thanks in advance
