1Back to top Go down   The four manifold stacks  Empty The four manifold stacks Sat Jan 14, 2012 2:12 pm
Domingo
Domingo
Hi there,
I've just been brought to this amazing world of BMWing recently, and right now I got a 24 old k 100 rs. I'm fixing a couple of things and a friend of mine is in position of cleanig some parts with ultrasonic cleaner, and my question is if there would be any problem cleaning the four manifold stacks whithout dismounting the TPS switch or, it will be damaged?
Thanks beforehand.
2Back to top Go down   The four manifold stacks  Empty Re: The four manifold stacks Sat Jan 14, 2012 3:27 pm
I wouldn`t put the TPS (with micro switches) into the ultrasonic bath.
It`s only two screws to remove it, and easily adjusted in position when mounted back again.
3Back to top Go down   The four manifold stacks  Empty Re: The four manifold stacks Sat Jan 14, 2012 4:25 pm
+1 yep good call inge
