1 k100 running problem Fri Jan 06, 2012 1:43 pm
johnhilditch
I have a 1985 K100.I bought it in November as a non runner.I finally managed to get it to fire up today after replacing the fuel pump and relay.My problem is that it runs rough and stops after a few seconds.If I try to open the throttle it stops.The rpm is very low(less than 200),as if it was only running on a couple of cylinders,which is probably why it's stopping.However all the exhausts are hot,all the plugs are firing(and in the correct order) and all the injectors are working,but it won't run as it should.All the filters have been renewed.Any ideas please? Best wishes.John
