1Back to top Go down   K 100 8v TPS adjust Empty K 100 8v TPS adjust Mon Dec 12, 2011 10:33 pm
Domingo
Domingo
Hi there,
As I told you in my earlier posts, I'm making a restyling in my 87 K 100 rs 8v and despite I've been searching some info in my usual forum about how to adjust the TPS connector:( Sad , no one gets answer for my question and here I am.
Please forgive me but try to understand that it's easier for me just for language use.:pale: :pale: :pale:
I'm reading this forum very often, improving my English and my "BMWish"Laughing Laughing Laughing Laughing
2Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Mon Dec 12, 2011 10:58 pm
club_c
club_c
You want to make the adjustment with the CHOKE off. Then loosen the TPS and turn it until you hear a 'click'. Then tighten up. Done.
1988 K100RS SE VIN 01477554
3Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Mon Dec 12, 2011 10:59 pm
club_c
club_c
And you are always welcome here. Just ask the questions and we'll talk until you understand.
4Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Mon Dec 12, 2011 11:33 pm
To double check if it is correct. The click is the microswitch working so when you open the throttle the switch should click right at the same time. It is a very fine adjustment and the closer you make it the better it works.
The bike will run well without the switch working at all so if you set the switch so when you return the throttle to the off position the switch has not clicked the bike is better to ride at slow speeds in heavy traffic. If I have confused you please ask again. I will not yell at you as the English do.
5Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Mon Dec 12, 2011 11:37 pm
club_c
club_c
K Freak wrote:I will not yell at you as the English do.
Oh, those Englishmen....
6Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Tue Dec 13, 2011 12:17 am
andyb
andyb
Hi all, I assume you do this adjustment with the ignition on, but engine not running?
Andyb
7Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Tue Dec 13, 2011 12:34 am
The ignition does not need to be on as you hear the switch click as it turns on and off. You need to listen carefully as it is not loud. You could use a meter across the switch but you need to remove plug on top of the tps.
8Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Tue Dec 13, 2011 4:57 am
yep its just a mechanical click your listening for andy ..loosen both the screws either side of the tps swich assembly (can be tight so dont bend the mounts ) ....and easy to do ...good luck !!!
9Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Tue Dec 13, 2011 8:26 am
ReneZ
ReneZ
The above advise is applicable when the throttle set-up is correct. I have seen a few bikes that when you removed the TPS the butterfly valves suddenly closed further, the bike ran rough and, initially, no one knew what happened.
As indicated above, the TPS should make a clicking sound when you just open the throttle a bit. However, normally it is something you do after synchronising etc.
K 100 8v TPS adjust Adjustment1
K 100 8v TPS adjust Adjustment2
Rene
BMW K100 - 1985 (0030029) Scotland K 100 8v TPS adjust Rain
10Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Tue Dec 13, 2011 8:49 am
hmm thats kinda interesting rene .....i could certainly see the "choke " (ahem ) cable having more influence on the throttle bodies pretension ....but noted and checked
11Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Tue Dec 13, 2011 10:08 am
zonenfeile
zonenfeile
all pages as jpg needed ?
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
12Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Tue Dec 13, 2011 10:53 am
zonenfeile wrote:all pages as jpg needed ?
No but a trip to the barber is, looking at your new avatar Razz bad night at the Christmas Party??? santa
13Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Fri Dec 30, 2011 9:50 pm
Domingo
Domingo
ReneZ wrote:The above advise is applicable when the throttle set-up is correct. I have seen a few bikes that when you removed the TPS the butterfly valves suddenly closed further, the bike ran rough and, initially, no one knew what happened.
Thanks for your info Rene, I've found it highly useful.
Could you tell me where this info comes from?
I'd like to own one of these.
Merry XmasK 100 8v TPS adjust 22936
14Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Fri Dec 30, 2011 10:41 pm
Those pages are from the recently uploaded BMW service manual. If you have access to the download section, you will find the PDF file there. If you don't have access, contact Crazy Frog for the password and don't forget to make an introduction thread in the "Member Introduction" section of the site (one time, ask me how I found out Rolling Eyes )
15Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Wed Jan 04, 2012 4:01 pm
ReneZ
ReneZ
Those pages are from my own book that I bought at Moto-bins. I'm a person that likes to have a book with him when he does some maintenaince (easier, for me, to browse between pages) Indeed an electronic version is available through the download section.
Rene
16Back to top Go down   K 100 8v TPS adjust Empty Re: K 100 8v TPS adjust Thu Jan 05, 2012 10:15 pm
Domingo
Domingo
Thanks for that useful info.
Last week I've known about what realoem really is so, you can imagine how much I know about this matter.
I'll keep on growing up in the K's knowledge.
Regards
