1Back to top Go down   So, do anyone know? Empty So, do anyone know? Mon Jan 16, 2012 4:05 pm
Norfolk_Boi
Norfolk_Boi
How I could get the charging system and starter to work, without the clocks on an 1984 K 100? Is there a way to bypass whatever's causing the starter and charging system to not work?
2Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Mon Jan 16, 2012 4:22 pm
I`ve allready provided you a link about that under the topic "your own restauration".
You can use the solution in that thread for the starter interlock.....or just pull the clutch, to bypass.
The charging monitor lamp the charging circuit needs to function, if you don`t like it...hide it somewhere.
3Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 2:40 pm
yes a good bit of info that too inge thanks
seemed to work for the guy and im sure others
4Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 4:08 pm
Norfolk_Boi
Norfolk_Boi
Yes you did. Thanks. I'm however no good whatsover with electrickery and was hoping for it explained in layman's terms Embarassed
5Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 4:39 pm
And which part do you need in particular a detailed explanation for?
6Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 4:46 pm
Norfolk_Boi
Norfolk_Boi
Well. I am a complete numpty with electrics. I was hoping that I could simply 'bridge' the wiring to make it work? If so which wires are they? I really am daft when it comes to electrics Embarassed .
7Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 5:08 pm
If you want a easy solution, you can bridge the connector at pin 5 and 6.
Respectively a green/black and a black/green wire, but then the starter
would engage in whatever gear you have selected.
Or as earlier mentioned, just pull the clutch lever.
8Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 5:14 pm
Speedy Inge, I was typing the same answer but you beat me by 1/2 second to post yours.
Why would you bypass such a great security feature like this one?
CF
So, do anyone know? Frog15So, do anyone know? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
9Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 5:19 pm
Easy answer, no.
10Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 5:25 pm
Just found a new annoying layout for a reply... So, do anyone know? 167893
Did you answer NO to remove this feature?
11Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 5:33 pm
Takes more than that to annoy me, especially on a enjoyable place like this.
No, I wouldn`t have removed it.
12Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Tue Jan 17, 2012 7:36 pm
Norfolk_Boi wrote:Well. I am a complete numpty with electrics. I was hoping that I could simply 'bridge' the wiring to make it work? If so which wires are they? I really am daft when it comes to electrics Embarassed .
There is a way to do what you want and it is fairly easy.
The fix for a neutral start is not so simple so you may just be easier to start by pulling the clutch in and that overrides the neutral start bit. What you need to do is hook up 3 relays in series so the neutral light comes on only when in neutral.
With regard to the charging the alternator needs the current flowing thru the red light to excite the fields to get it to start charging so you need to replace the red light with an other light or similar. Pin 9 on the multi pin connector on the instrument cluster is the charging light circuit so a 3 watt bulb on that to earth will do the job. Also Acewell make an aftermarket cluster that will fit the K100 but you still need to do some wiring mods to make it work. http://www.acewell.co.uk/ have a look they are fairly good stuff.
13Back to top Go down   So, do anyone know? Empty Re: So, do anyone know? Wed Jan 18, 2012 3:42 am
Crazy Frog wrote:Just found a new annoying layout for a reply... So, do anyone know? 167893
now im getting giddy ....just off the plane too ....crikey !!!
