1Back to top Go down   replacement rear disk  Empty replacement rear disk Wed Dec 21, 2011 9:46 pm
beanoldboy
beanoldboy
G'day all , happy nailing Jesus to a tree season (don't get me started on that )
The rear disk on the RT is getting a bit narrow. i don't have a micrometer but the lip tells me it is an original ( solid , no slots)
Does any one from here have any info on the rear disk , can i use an old abs disk for my non abs bike (do you have one , can i buy it from you etc etc)
OR . .. does anyone know about aftermarket disks and how much they should cost, i have seen prices from 150 to 600 Australian dollars
I saw one advertised as stainless steel , may have been the 600 dollar one , any one know the advantages , other than its resistance to stains ?
again happy this time of year , be safe and we shall reconvene on the other side.
N.
Last edited by beanoldboy on Wed Dec 21, 2011 9:48 pm; edited 1 time in total (Reason for editing : punctuation and good taste.)
http://www.airware.com.au
2Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Wed Dec 21, 2011 10:04 pm
JR_K100RS
JR_K100RS
G'day Beanoldboy ,
when my fronts went under limit I decided on "Braking" brand , made in Italy , very good quality , you have to grind of the rivets & then very carefully punch them out ( too much force will distort the alloy carrier , I stuffed one up when doing mine ) it is the same part number for the rear I believe , the kit includes all the bolts etc , got better braking after they where bedded in . BM Motorcycles in Melbourne can give you a price , another option is EBC , they have a replacement disc & carrier option , I'm now due to replace my rear as well & I'm going to try the EBC unit from Motoworks UK , they are saying 160 pounds plus postage .
Hope this helps you
JR
Melbourne Australia
3Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Wed Dec 21, 2011 10:05 pm
Resistance to stain and rust is the only advantage. Aa iron disc will give you much better braking but many people dont like the rusty film they get if left standing for a few weeks.
I put an EBC on my K1100. It's fully floating, has vent holes, is iron and is much better than OEM.
Metal gear who sell on ebay are at Narangbar just north of Brizvegas, they dont have a rear disc but I believe that the front and rear disc are the same rivet pattern and only the carrier is different. Most of the after market discs have provision for the ABS ring, they aren't difficult to change.
If they are resisting comming of the old carrier a bit of heat usually expands them enough to fall off.
If you buy used one be very cautious as they very quickly wear to below the limit. A K1100 is about 2mm thicker and is interchangeable.
4Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Wed Dec 21, 2011 10:16 pm
beanoldboy
beanoldboy
thank you for the sharing of info , in light of news to hand , ie interchangeability of front and rear , ill get confirmation of this and buy one of the local aftermarket jobs , cheers again .
I reckon it would take me 20 years to acquire this depth of knowledge on k bikes , my favorite saying goes 'between the two of us we can get three times as much done'
N.
5Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Thu Dec 22, 2011 12:44 am
beanoldboy
beanoldboy
not nailing to tree time, born in the shed time , my mistake .
6Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Thu Dec 22, 2011 5:40 am
Aw N its really the time we stop hogging the sun and sent it northwards again that why they are all singing and dancing, we've relinquished our rights to it for another year. Keith
7Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Tue Dec 27, 2011 7:30 pm
beanoldboy
beanoldboy
sol invictus, our victory over the sun.
8Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Tue Dec 27, 2011 7:58 pm
I recently installed a K1100 rear disk on my K100.
The K1100 disk is thicker but still fit with the original caliper. I just had to remove the ABS crown.
CF
replacement rear disk  Frog15replacement rear disk  Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
9Back to top Go down   replacement rear disk  Empty Re: replacement rear disk Tue Dec 27, 2011 8:47 pm
beanoldboy
beanoldboy
thanks CF, i did entertain this, but as i am looking at a new disk there isn't much to be saved, think it might be a weekend wheel off full brake rebuild type affair, no point doing a half a job eh ?
