1Back to top Go down   What is this sensor? Empty What is this sensor? Tue Dec 20, 2011 3:40 am
Albyalbatross1
Albyalbatross1
Hi all, Having a brain fog of a day scratch . Got my water temp sender in the mail to fit the drain hole in water pump. yes it fits right in but I am almost certain it is actually an oil pressure switch. I have looked high and low but just not able to find it. can anyone put me straight on this please? These are the details stamped on it. 0.060+- 0.020 bar 1459 416 4 84
What is this sensor? Imag0611
What is this sensor? Imag0612
2Back to top Go down   What is this sensor? Empty Re: What is this sensor? Tue Dec 20, 2011 4:48 am
yep looks like an oil presure switch to me ....cant find a reference in the real oem lists alby
i thought the temp switch was a lot smaller in size ...
3Back to top Go down   What is this sensor? Empty Re: What is this sensor? Tue Dec 20, 2011 5:40 am
That is an oil pressure switch absolutely no doubt, the temp switch is as you say much smaller. I have just had both out on the K100 to do a water pump seal.
4Back to top Go down   What is this sensor? Empty Re: What is this sensor? Fri Dec 23, 2011 4:57 pm
That is a pressure switch it even has the rating in bar on it.
5Back to top Go down   What is this sensor? Empty Re: What is this sensor? Fri Dec 23, 2011 6:57 pm
beanoldboy
beanoldboy
agreed, water temp sender unit is smaller with two spade terminals at 90 degrees.
http://www.airware.com.au
6Back to top Go down   What is this sensor? Empty Re: What is this sensor? Fri Dec 23, 2011 10:52 pm
Albyalbatross1
Albyalbatross1
Yes I have the correct sensor on its way. beanold boy..The sensor i am after is only for the water temp. It is for the actual temp gauge.
7Back to top Go down   What is this sensor? Empty Re: What is this sensor? Fri Dec 23, 2011 11:23 pm
good one alby ...cheers mate
