1 Help needed with lubricant on clutch Wed Dec 21, 2011 7:49 pm
caferacer62
Ok i have the clutch and flywheel out to replace main seal. Noticed that main seal is genuine item but was recessed into housing about .5mm. Not that it concerns me as i am using non genuine seal and will install flush( as per KFreaks advise).
Going to put clutch back in tonight, i have looked at the manual and it states about lube on clutch surfaces. I understand the lube on splines ,wire ring and bush, but not the other surfaces. Can anyone shed some light on this. I'm not used to lube on clutches!
Bert 2.0
