1Back to top Go down   Lokcs for side cases Empty Lokcs for side cases Mon Dec 05, 2011 9:27 am
Domingo
Domingo
I've just purchased an 87 K 100 RS and surprisingly for me both side cases don't have key locks.
Could someone tell me if there are locks for them or should I change the side cases buckles?
Thanks before hand
Very Happy Very Happy Very Happy
2Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Mon Dec 05, 2011 1:02 pm
club_c
club_c
Are they locked or unlocked right now? There is a key code on the buckle on the early ones. Do you have to lift up a little cover to put a little key in, or does the ignition key fit into the lock? That will tell us more about what kind you have.
1988 K100RS SE VIN 01477554
3Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Mon Dec 05, 2011 3:54 pm
Domingo
Domingo
They don't have any lock and buckles don't seem to be prepared for having them.
I can open the side cases but the problem is that anyone could do it as well
I'll try to take some pictures for a better understanding.
Thanks for answering
4Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Mon Dec 05, 2011 4:48 pm
club_c
club_c
I think you have the first generation cases. There is a little black tab on the top of the buckle that you can lift up and swing to the side. The keyhole is under this tab.
5Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Mon Dec 05, 2011 5:51 pm
Domingo
Domingo
club_c wrote:I think you have the first generation cases. There is a little black tab on the top of the buckle that you can lift up and swing to the side. The keyhole is under this tab.
After reading your post I've realized that with the keyring I was given, apart of the ignition keys and topcase keys, there were a couple of smaler keys that the previous owner didn't know where they were from. I'll see if they're the sidecases' keys.
I'll keep you up to date about that matter.
Smile Smile Smile
6Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Mon Dec 05, 2011 7:56 pm
club_c
club_c
Yes those locks use a smaller key, something like a suitcase key. I bet you've got everything you need.
7Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Tue Dec 06, 2011 9:17 am
Domingo, I had the same experience with my cases. I got a tiny key that didn't seem to go anywhere until I got the cases off and saw the little black tab Club C refers to. Now I have replaced the gasket (rubber seal) on the case lids and have everything locking even the cases lock to the bike. Feels much more secure knowing they are locked on.
88KE
Lokcs for side cases Ir-log1188....May contain nuts!Lokcs for side cases Ir-log11
K75RTP - 1994
8Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Tue Dec 06, 2011 1:00 pm
Lokcs for side cases 2011-110
9Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Tue Dec 06, 2011 1:31 pm
club_c
club_c
+1 Charlie!
10Back to top Go down   Lokcs for side cases Empty Re: Lokcs for side cases Tue Dec 06, 2011 4:31 pm
Domingo
Domingo
Yeaah, that's like mine.
Thank you so much guys.
I'm very pleased to belong to this forum.
I hope some day to be able to help someone here.
