1Back to top Go down   new member of forum Empty new member of forum Thu Apr 05, 2012 9:04 pm
ken conner
ken conner
Hi , I am a new member . I have a 89 k/100 rs . I have steering issues that I am going to let a local scooter guru work on. This thing refuses to turn . We think it is steering head bearings - I have parts on the way from BMW dealer. Can anybody tell the proper way to torque the new ones in place ? I don't have a repair manual , but if needed I can buy one. THANKS A BUNCH !!! I love this forum - you people are great !new member of forum 112350
2Back to top Go down   new member of forum Empty Re: new member of forum Thu Apr 05, 2012 9:14 pm
No real need to "torque" them but grease them before assy then do the adjuster up firm and rotate the clamp a few times and repeat the process till any grease except fot the thin film is squeezed out and do up the adjuster till firm and no play. Check after you have put the tpo clamp on and tightened it down because occasionally is slacks off a bit with the top clamp. A bit like wheel bearings are done. If you give too much preload they will notch very quickly. Its very much a matter of feel.
3Back to top Go down   new member of forum Empty Re: new member of forum Thu Apr 05, 2012 9:34 pm
A bit from the manual could also be helpful:
new member of forum Beskri10
new member of forum Skisse10
4Back to top Go down   new member of forum Empty Re: new member of forum Fri Apr 06, 2012 12:50 am
hiya ken ....
welcome to the forum .
youll have to post up a pic for us one day huh ?
5Back to top Go down   new member of forum Empty Re: new member of forum Sat Apr 07, 2012 6:36 am
Welcome Ken.
I've shifted your post to the Frame, fairing and wheels section.
6Back to top Go down   new member of forum Empty Re: new member of forum Sat Apr 07, 2012 6:18 pm
club_c
club_c
Hi Ken, that is something I have seen before too. You should replace the bearings, but in the meantime, try hitting th upper and lower bearings with some WD-40 or similar. It may loosen up the solidified grease enough to at least move it around.
1988 K100RS SE VIN 01477554
7Back to top Go down   new member of forum Empty Re: new member of forum Sat Apr 07, 2012 7:12 pm
club_c wrote:Hi Ken, that is something I have seen before too. You should replace the bearings, but in the meantime, try hitting th upper and lower bearings with some WD-40 or similar. It may loosen up the solidified grease enough to at least move it around.
I can attest of the efficiency of the WD40 for this application. You may even not to have to replace the bearings. On my bike, the grease dried up and became like a varnish. Spraying WD40 softened it and the bike acted as new. I even didn't have to re-adjust the bearings.
That was a cheap temporary fix until I rebuilt the bike.
new member of forum Frog15new member of forum Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
