1 Synchronising fuel injectors Sun 18 Jan 2009, 14:33
Comberjohn
Has anyone experience of syncing the injectors? I have used my Morgan Carbtune on bikes with carbs in the past with good results but having problems with the K100. The Carbtune is well recommended AND its made in Belfast but available worldwide. Morgan Carbtune
Thought that the engine could do with a tune up as it sounded a bit rough at tickover (someone said they all do!) and to try to cure a very slight hesitation from tick over. Bit irritating in traffic.
When I put the Carbtune on they were a bit out but I couldn't get them anywhere near level without some extreme adjustment. i.e. one air screw almost fully in and one on its last thread before it fell out.
Checked all the hoses for leaks or cracks and all appeared ok. Checked the inlet manifolds for air leaks by spraying them with contact cleaner while running. They were ok too.
Had to put the air screws back to where they where. Tickover is just under 1000 rpm which is within spec but can't be adjusted any lower.
Couple of theories on the problem.
Can the co2 settings on the air volume meter affect the injector syncing?
I know that in the olden days, when syncing SOHC Hondas(sorry), it was advisable to adjust the valve clearances before doing the carbs and was wondering if that could be my problem.
The engine has 26,000 miles on it and doubt if the valve clearances have ever been checked. I haven't had it for all of the 26,000 miles, by the way. Just keep putting off checking them since I got it at 18k.
Any ideas before I start tweaking the linkages? I'm getting desperate!
