1 Hot Grip wires Thu Oct 06, 2011 12:04 pm
BooG
Have got some hot grips I want to install for Winter. From the grips, the wires meet via two blocked connectors. Another blocked connector joins the thermostatic switch to the loom at the same point. The wires resolve into a fused red wire, and a ringed earth in black. What is the best way to connect to the K75 loom? Should I use the existing connectors under the tank in some way? Is a relay the best way to go? If so, how do I do that? I'm OK doing most stuff, but I hate electrics! I've read various posts, but I think I need an "Idiots Guide'! Will try and get some photos up if I can work out how to......
