1Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty 84K100RT,87k100rs,90k100lt...... Thu Jan 26, 2012 6:55 am
ASTF11
SO.......i finally had to buy ....those three to hope and build me one!!!
i rode the 84RT for 500Km back home:
she drank more than 9 liters for each hundred km (instead of 5-6l\100KM) and made a kind of distribution noise between 2500and 3500revs(chain rattling on the cover?)
i brought the 87rs on a trailor as she was crashed but engine started ok and ran smooth except under 1200revs a nasty 'clang clang'(intermediate shaft rivets ?)
to day i go to get the 90lt (theft damaged only saddle and counter missing)with the trailor !
i spent only 1800euros for the lot !
the 84rt is apart(engine,gearbox,transmission)and will be used as donor or trial (i mean to try and take it all apart) bike and i m ready to spend some hours building one to put back on the road!!
meanwhile i learn theoreticcally from this forum
thanks
2Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Thu Jan 26, 2012 7:30 am
Good one you will have heaps of spares.
3Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Thu Jan 26, 2012 9:41 am
Sounds like good value. What form will the finished project have? RS or RT/LT? We look forward to seeing your project!
88KE
84K100RT,87k100rs,90k100lt...... Ir-log1188....May contain nuts!84K100RT,87k100rs,90k100lt...... Ir-log11
K75RTP - 1994
4Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Thu Jan 26, 2012 5:14 pm
Good on you ASTF11
that sounds like a great idea. Get yourself an English book of swear words, it seems to help.
Cheers RT
5Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Thu Jan 26, 2012 6:13 pm
Oldgoat
Oldgoat
Nice work Eleven. Very smart of you to get the spares...makes trouble shooting and sorting out so much easier. Looking forward to seeing your work. Post a pic or two when you get a chance?
OG
6Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Sat Jan 28, 2012 7:42 am
ASTF11
hi everyone !
got the 90lt k100 yesterday:
first problem its abs model and the instrument cluster is missing (plug seems diff from the non abs one?
first i want to start the engine :for this purpose do i really need the instrument cluster to be plugged in?
thanks
7Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Sat Jan 28, 2012 9:30 am
No but you will need to pull the clutch in to give power to the starter relay.
8Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Sat Jan 28, 2012 1:44 pm
ASTF11
thanks kfreak it is so amazing for me in old europe to get helped from so far away in australia!!
to night nearly snowing round here will give it a try tomorrow!!
thanks
9Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Sat Jan 28, 2012 2:15 pm
C'est cela l'Internet et faire parti d'un groupe d'enthousiastes.
(That's the beauty of Internet and belonging to a group of enthusiastic people!)
CF
84K100RT,87k100rs,90k100lt...... Frog1584K100RT,87k100rs,90k100lt...... Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
10Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Sun Jan 29, 2012 3:43 am
ASTF11
yes crazyfrog i love it
while fiddling aroundon my k i met a funny devive at the central stand(kind of lever related to the side stand also?)didnt take enough time to discover the whole thing but may this interfere with ability to start the engine?(kind of safety device for not being able to start the engine while on side stand?)
11Back to top Go down   84K100RT,87k100rs,90k100lt...... Empty Re: 84K100RT,87k100rs,90k100lt...... Sun Jan 29, 2012 8:58 am
I`ll guess this switch is wired the in same manner as the early K11`s, and then cutting the positive signal
to the fuel pump relay.
After some history with fried wires, this was later changed cut the negative signal to the starter
and Motronic relay.
