1Back to top Go down   final drive seals? Empty final drive seals? Sat Sep 24, 2011 12:47 pm
gabriel
I noticed a small quantity of oil leaking from the final drive whenn I loosened the four screws which attach it to the swing arm...i noticed there is an output andd input seal listed on the Motobins website.
can anyome tell me what are these seals, where are they located in the final drive and how to replace them.
I know about the large o ring but was not aware of the other two seals.
any suggestions awill be appreciated.
2Back to top Go down   final drive seals? Empty Re: final drive seals? Sat Sep 24, 2011 1:45 pm
If your FD output seal was leaking, you would have oil on your brake disc.
Oil inside the swingarm can come from two places, gearbox output, FD input (or both).
3Back to top Go down   final drive seals? Empty Re: final drive seals? Sat Sep 24, 2011 2:02 pm
Part #4, input seal, special tools needed.
final drive seals? 23010
Part #1, output seal, changing it is straightforward.
final drive seals? 1010
4Back to top Go down   final drive seals? Empty Re: final drive seals? Sat Sep 24, 2011 4:18 pm
output seal is located in the bell housing behind the disk brake
here is a picture of it removed from the area
be sure you havent overfilled the final drive if you have a leak at the input seal ....also check that there isnt too much play in the pinion ,,,,by that i mean the pinion should not move in and out along its axis (happened to me )
final drive seals? Pictur21
