1 cooling fan Sun May 15, 2011 5:20 pm
kartooo
been away from bmw's for a while,had a k100lt,a r80rt and just now picked up a 1985 k100 with just 12k on it.
noticed right off the fan did not come after running parked for 15 minutes or so. did al the checks and then when i poked around in the relay box it would come on occasionally. pulled out the temp/fan relay to find 2 pins stll left in the female connector. guess after 26 yrs their solder gave out. soldered them back in and all is well. 1st ride also showed a noisy rear end. found the large ball bearing inner race to be bad. guess all that sitting with no lube splashing around and possible condensatein did a job on it. $85 bearing on the way. love the sound of this thing at around 6k rpm....
