Number of posts : 11701
hi chrono ...havent seen a good write up on the replacement process throughout ....but
you will need about 6 inches of 1/4 inch inside sae 30r10 for the breather tube inside the tank ...about a foot of 8mm inside dia 30r10 for the fuel pump to filter then to the feed internal to the tank
about 1 meter (3 feet) of 30 r 9.. 8mm id hose for the high presure line to fuel rail ...short section from fuel rail output to regulator , and a bit for the return line back to the tank from the regulator all the same stuff
explanation ...the 30r10 is rated for unleaded and fully imersed in fuel so both inside and outside the hose is the right stuff ....the 30r9 is again rated for unleaded ...but not inside tank ...the inner lining is the important reguirement on this section
hose clamps might have to be reviewed or a good way of putting them on found if you intend to keep the same ones there ....as the older hose will be thinner .
hope that helps some ..
