1 Oil Leak from front of motor Wed May 11, 2011 7:10 am
club_c
I have this infuriating little oil leak at the front of the motor that I cannot find. Thought it was the cam timing chain cover and resealed it 3 times, so that's not it, then thought Hall Sensor cover but that's not it, so now I'm thinking water/oil pump cover. The question is, if I pull off the cover, what happens? Does oil and coolant gush out, or just weep a bit? Or does it not leak oil ever so look somewhere else?
