1Back to top Go down   Cable routing Empty Cable routing Sun Apr 19, 2009 8:55 am
ReneZ
ReneZ
Hi, is there anybody who can tell me where it is shown how the throttle and clutch cables are to be routed under the tank of a K100RT - 1984? Thanks, Rene.
2Back to top Go down   Cable routing Empty Re: Cable routing Mon Apr 20, 2009 7:01 am
I had a big problem with it when I re-assembled my K100.
At the end, I routed the cables without attaching them to the clutch or FI rail, and found the position where they could move freely (many tries).
They are going between the instrument cluster and the dash (where the ignition key is) and then go under the plastic cover on side of the steering column.
Too bad that I didn't take pictures.
3Back to top Go down   Cable routing Empty some scans from the BMW Shop Manual Mon Apr 20, 2009 8:50 am
roys
Hi,
Not exactly what you wanted but I hope still usefull.
Roy
Cable routing Page_411 Cable routing Page_412 Cable routing Page_413 Cable routing Page_415
4Back to top Go down   Cable routing Empty Re: Cable routing Sat May 02, 2009 2:33 am
kavka
Here are some pictures of my bike. Mybe it will help you. I'll try to find more. There must be picture in my comp, somewhere.
Gorazd
5Back to top Go down   Cable routing Empty Re: Cable routing Sun May 03, 2009 6:16 pm
suus62
suus62
Should I take some pics and send them to you? Mine is a K100LT '90 european version. You might see it next year on the M&G at your premissis.
Frank
CB250 CX500 K100LT K1200RS
First find the problem then the solution will present itself.
6Back to top Go down   Cable routing Empty Re: Cable routing Mon May 04, 2009 7:17 am
ReneZ
ReneZ
Frank, graag, yes please, thanks!
Phil has sent me some, but you can never have enough I guess. We can put them somewhere on the sites, as the manuals don't give any information on the bowden cables (to my knowledge).
For all, we are trying to organise a M&G (Meet and Greet) at/around my location in Scotland next year with members of a Dutch forum. Looking forward to it!
Thanks all!
7Back to top Go down   Cable routing Empty Re: Cable routing Sat May 09, 2009 10:50 am
suus62
suus62
Cable routing DSC02607
Cable routing DSC02608
Cable routing DSC02611
Cable routing DSC02612
Cable routing DSC02613
Cable routing DSC02614
Cable routing DSC02615
Cable routing DSC02616
Cable routing DSC02617
Hope this will serve you well.
The last photograph shows the bowden cable of the clutch not being held by the tie rip. It should be held by tie rip to the frame.
By the way I found a problem that occured as I had been working on the front wheel. Since I had disassembled and assembled it the choke light lit every time I turned the steer left and right. A broken tie rip cause it (8th photopraph); the choke cable (bowden) had to much play.
Frank
8Back to top Go down   Cable routing Empty Re: Cable routing Sat May 09, 2009 4:23 pm
ReneZ
ReneZ
Team, many thanks for all your help, that was great!! Cheers, Rene.
