1Back to top Go down   Introducing the K-IC3000 Empty Introducing the K-IC3000 Mon Jan 16, 2012 12:06 am
Albyalbatross1
Albyalbatross1
As you are all aware, it can take some time to send your injectors away for cleaning. Now lets be honest..Are you really getting your own injectors back, are they really new parts..
The ONLY way to be sure is to clean your own. For that task you will need a few bits and pieces..A search on GOOGLE and You Tube is the best to find the bits and pieces..
The only thing you will not be able to find is THIS The K-IC3000 This is used to get the best cleaning possible for BMW K Bike injectors.
Introducing the K-IC3000 Resize45
Introducing the K-IC3000 Resize46
This new device allows the user to test individually for coil duty cycle, and to fire the injectors continuously while in an ultrasonic cleaner or running presurised cleaning agent through the injectors.
Manufacture has been limited to a very small number for now. BMW recommends using this unit for absolute best results for cleaning the cermic innners of your K-Bike injectors.
I will post a short video of the unit in action later in week. If you want to know more about this great unit..Please contact me.
Last edited by Albyalbatross1 on Mon Jan 16, 2012 3:37 pm; edited 2 times in total (Reason for editing : ..)
2Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Mon Jan 16, 2012 12:52 am
Whoo Hoo!
Doesn't that look sweet!
Nice red colour...BMW symbol. I bet it costs a bomb to buy it.
3Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Mon Jan 16, 2012 1:07 am
caferacer62
caferacer62
I may not be very smart, but that looks a lot like a battery charger with some fancy buttons and an expensive sticker. Very Happy
Who is this Motley Crew you speak of.
Bert 2.0
Introducing the K-IC3000 170874
4Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Sat Jan 21, 2012 5:24 pm
It's not April 1st is it? Well done though!
5Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Sun Nov 11, 2012 9:10 am
Rjtrucker
How does it test the coil? You need to use an ohm meter to test the coil. Also when I do injectors you do get yours back. If asked I include your old o-rings and screens. How do you measure the flow with that thing? Only way to be sure they are all flowing the same amount is to measure the flow over a few different rpm ranges and fuel pressures. Also leak test. Most common problem I find on old injectors is leaking. You need to keep the injector under full operating pressure for 60 seconds while closed and not get any dripping. And my turn around time is 24 to 48 hours. (Last 2 weeks were an exception due to no power or Internet due to hurricane Sandy followed by a foot of snow 3 days later.) but all up and running again here. (I did not want to risk using my flow bench on the generator.). But for you do it your self guys I do stock all the replacement parts for the k bike injectors.
Ron S
NJ USA
74 R90/6 cafe project
93 K11LT
85 K100RS
85 K100RS turbo project.
And a load of K100 projects and parts.
6Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Mon Nov 12, 2012 5:08 pm
club_c
club_c
RJ I believe this was a gag...
1988 K100RS SE VIN 01477554
7Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Mon Nov 12, 2012 8:26 pm
club_c wrote:RJ I believe this was a gag...
No gag, Clubbie...them Queensland boys went out and knocked their heads together and built it.
8Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Mon Nov 12, 2012 8:56 pm
With the help of our Chinese friends? (Looks very good but doesn't work) Introducing the K-IC3000 652573
Introducing the K-IC3000 Frog15Introducing the K-IC3000 Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
9Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Tue Nov 13, 2012 12:22 am
Albyalbatross1
Albyalbatross1
Very Happy Very Happy Very Happy
RJ The K-IC3000 does actually work. This came about as there are not many places who service injectors in QLD. So we did what any Aussie does when faced with paying rip off prices..improvised!!
It is designed to actuate the injectors one at a time. (not enough amps for any more) You need to manually test the coils with your meter and as for pressure testing...Spare fuel rail/pump and fuel line.Clamp it on and go. (after a bath in the 500w sonic cleaner) Flow rate is whatever looks good in the measureing jug. Smile.
We can order the filter baskets and o-rings and caps locally.
It works out to around AUD$2.00 for each injector to be serviced. Far better than AUD$70.00 each :affraid:quoted in Toowoomba!!!
The K IC300 is for sale as a franchise!!!!! Introducing the K-IC3000 652573
10Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Tue Nov 13, 2012 1:00 am
There's also this DIY design:
Dinofab Fuel Injection Tester
I built this and it works. I have the PCB design if anyone else wants to give it a go.
11Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Tue Nov 13, 2012 3:34 pm
club_c
club_c
Whoops, apologies extended gents...
12Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Wed Nov 14, 2012 11:53 am
Rjtrucker
I never realized things were that expensive down there. Going rate in the states is between $16 and $22 an injector. I charge $15 each plus 10% off for forum members. I should send you a flow bench and you can do them there for a better price and it will be a world wide franchise. Seems there are a lot of K bikes in that part of the world. The flow bench also does oilhead R bikes and even the newer K bikes.
Ron S
NJ USA
93 K11LT
85 K100RS
13Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Wed Nov 14, 2012 2:59 pm
Albyalbatross1
Albyalbatross1
IT is sad and true. Down uder we gotta do our homework and shop around. If not for onlineshopping it would take a long time to replace those much needed parts.
14Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Wed Nov 14, 2012 8:19 pm
To give you another example of the costs here RJ I bought a 320iBMW sedan car and it needs a few things doing as with the K bikes when we first buy.
A pair of radiator hoses (top and lower) were near $140 from the local auto store (not BMW) so I bought a complete set of cooling hoses (10 different hoses), a gasket for the timing chain cover, an oil line that apparently gives out around 250000kms and a cooling tube for the alternator (small plastic part) I got all of that for $140 plus $26 freight from PA. The retailers here just can't work out why we are shopping overseas and are complaining about us not being patrotic and buying local etc.
15Back to top Go down   Introducing the K-IC3000 Empty Re: Introducing the K-IC3000 Wed Nov 28, 2012 7:50 pm
This is an example of the pricing difference between the States and OZ, and I have worked in BMW car and bike shops in both places over the years, and recently too:
In '07 I was touring across the south of OZ on my RS Airhead when I noticed a leaking caliper seal at the back end. I went online and got the part number (and US retail price) and then rang the local BMW bike dealer in Melbourne. I was shocked to find out that it was $65 just for the seal kit and that he'd have to order it in from Germany and wanted me to pay the freight. I politely declined his offer. In the US it sells (retail) for $22 and was available to be posted straight away from the Tacoma, WA shop I'd worked in. Since it wasn't leaking terribly badly I asked them to post it to me and in three weeks when I was back up north in Queensland it was on my doorstep from the US for under $30 all up.
That is a small but clear example of the price difference we have to pay Down Under, and our puny dollar is currently worth $1.04752 to the Greenback (www.xe.com/ucc). It's more than the tyranny of distance we are talking about here. It's a greater margin made by distributors and the fact that the US has a far larger buying power than OZ does. Call it the economy of scale. Also, BMWNA bid for and buy their expected parts order from BMW GMBH a year or two in advance and so they have greater sway in what they'll pay than tiny little BMW Australia do.
I'm with Rick and Alby (and the lot) who shop around and go offshore for even the basics, given time constraints, and we all know that a "penny saved' is more for the petrol in our tanks...and that's another $tory too.
At the end of the day, to help dispel a myth some people have in their heads, the parts margin from cost to retail is about 40% for a North American dealer (if the parts manager is buying correctly) on factory parts, and in OZ it's only 35%. What those dealers decide to do with pricing structure (artificially raising retail prices) is up to them given the ability of computers to "matrix" the prices to increase margin.
