1Back to top Go down   Clutcharm? Empty Clutcharm? Wed Apr 13, 2011 9:36 am
wikur
wikur
I`ve just orderd bearings,axle and wire from Motor-bins.
My clutch action has been a little stiff and I`m about to improve it.
What do you think about fitting a grease nipple on the arm?
I think Motorworks got one listed.
Cheers,Wikur!
2Back to top Go down   Clutcharm? Empty Re: Clutcharm? Wed Apr 13, 2011 10:36 am
Avenger GT
Avenger GT
Just drill it, tap it and fit a grease nipple. Very easy to do. Should get grease nipple from any agricultural parts supplier or garage.
3Back to top Go down   Clutcharm? Empty Re: Clutcharm? Thu Apr 14, 2011 7:40 pm
wikur
wikur
Thanks Avenger!
I was about to do it myself,got the idea from Motorworks.
Strange that BMW didn`t do it from start.
I`ve never heard that this is a common problem on K`s tough.
My cluth cable is from-88,never been replaced.
Maybe the wire is beginning to cut through the teflon coating?
Cheers,Wikur!
4Back to top Go down   Clutcharm? Empty Re: Clutcharm? Thu Apr 14, 2011 11:12 pm
Avenger GT
Avenger GT
Actually it is a common problem, caused by the rear mudguard being too short at the front. Water and muck get dumped straight down on to the clutch arm. My own one was half seized but I managed to get the rod out of it by tapping it over and back a few times to loosen it. I had another on a friend's K75 that was so seized up that the rod was turning in the two lugs on the back of the gearbox. I had to cut the rod with an angle grinder to get it apart. Better to sacrifice the clutch lever than break the lugs off the gearbox!!!!!
5Back to top Go down   Clutcharm? Empty Re: Clutcharm? Thu Apr 14, 2011 11:31 pm
i guess it should be serviced every now and again ...its a needle roller isnt it ?
6Back to top Go down   Clutcharm? Empty Re: Clutcharm? Fri Apr 15, 2011 2:56 pm
Yep, needle roller.
7Back to top Go down   Clutcharm? Empty Re: Clutcharm? Fri Apr 15, 2011 5:38 pm
its amazing isnt it ?...anybody else designing and then building a production bike would just put in a brass/plastic bush .....
20+ years and it still works ....omg ..stunning
8Back to top Go down   Clutcharm? Empty Re: Clutcharm? Fri Apr 15, 2011 7:27 pm
ReneZ
ReneZ
The later bikes had an extra flap on the front of the mudguard to prevent most of the fouling of the clutch mechanism.
Rene
BMW K100 - 1985 (0030029) Scotland Clutcharm? Rain
9Back to top Go down   Clutcharm? Empty Re: Clutcharm? Fri Apr 15, 2011 9:31 pm
Avenger GT
Avenger GT
I made a mudguard extension from an old plastic oil can. Light and flexible and does the job.
Clutcharm? Photo013
Clutcharm? Photo014
10Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sat Apr 16, 2011 3:26 am
ReneZ
ReneZ
Looks good!
Rene
11Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sat Apr 16, 2011 5:43 am
BMW has an extension part available I wrote a post about it a while back when I fixed mine. One comment made at that time was a spray of chain lube on each end of the clutch are on a regular basis prevents any water getting in and seeps into the rollers. I have given mine a shot once every two months or so since then as well as fitting the extended guard.
12Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sat Apr 16, 2011 11:11 am
K-BIKE wrote:BMW has an extension part available I wrote a post about it a while back when I fixed mine. One comment made at that time was a spray of chain lube on each end of the clutch are on a regular basis prevents any water getting in and seeps into the rollers. I have given mine a shot once every two months or so since then as well as fitting the extended guard.
Vot is dis chain lube you talk of K BIKE it is a foreign concept to us.
Maybe you own something else you are not telling us about.
13Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sat Apr 16, 2011 12:55 pm
Oldgoat
Oldgoat
Nice work Avenger!
OG
Last edited by Oldgoat on Sat Apr 16, 2011 1:10 pm; edited 1 time in total (Reason for editing : update)
14Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sat Apr 16, 2011 12:57 pm
Oldgoat
Oldgoat
Oh, and would luv to see pics Wikur if you add a grease fitting!
OG
15Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sat Apr 16, 2011 6:44 pm
16Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sat Apr 16, 2011 7:26 pm
BIG D
BIG D
Cool
Top job blakey, yet another mod Penned in to do Very Happy
BIG D
17Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 3:18 am
Oldgoat
Oldgoat
This is what makes this board great. Very Happy Guys coming up with excellent ways to improve the ol girls and sharing their result!
Thanks Blakey!
OG
18Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 4:17 am
cheers blakey nice work
19Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 7:52 am
Excellent work Blakey and I shall do the same in the future, I still think the guard extension is worth putting on to keep the spray of filth away from the cable.
20Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 8:13 am
Oldgoat
Oldgoat
I'm doing it right now guys. Thanks again for sharing!
Clutcharm? Dscf0918
OG
21Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 9:04 am
Hey guys...here's a tip!
Drill the hole straight! Embarassed
K-BIKE, you are right. Install the extension as well.
22Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 9:06 am
Oldgoat
Oldgoat
Lol, after looking at the shape of the arm i'm thinking that might be easier said than done Blakey!
OG
23Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 9:10 am
Ol' ham-fisted me stuck it in a vice and went for it.
I was going to say don't forget to clean up all the swarf, but I won't 'cause you guys know what you're doing.
24Back to top Go down   Clutcharm? Empty Re: Clutcharm? Sun Apr 17, 2011 11:35 am
Oldgoat
Oldgoat
Hey Blakey,
I'm sure I've said it before, but I usually like to screw things up at least twice before I start learning anything so any and all advice before the fact is always appreciated!
OG
