1 Impeller shaft advice Sun Mar 20, 2011 6:15 pm
BooG
Have disassembled the pump and am at the re-assembly stage. Regarding the impeller shaft pitting; Mine shows distinct grooves around some areas, but they do not correspond to the critical sealing surfaces in the tech article,
http://www.ibmwr.org/ktech/water-oil-pump-rebuild.shtml
and the pitting is approx the same. I was thinking of doing some sort of salvage job with a thin layer of JB weld and some fine grade wet & dry. Good idea, or am I mental?
Also, do I have to replace my old cast iron impeller with the more "angled" version in the article (presumably with the spacer that comes in the re-build kit)?
