1Back to top Go down   Changing air-filter Empty Changing air-filter Tue Nov 29, 2011 2:30 pm
bjarnek100
hmmm...feel a bit stupid asking this but I just can´t figure it out. Do I really need to remove the radiator to change the airfilter on a RS16V. I cant figure out how to get the top part of the Air-filter box lifted high enough to rempoe the filter. Any good suggestions would be appreciated...
2Back to top Go down   Changing air-filter Empty Re: Changing air-filter Tue Nov 29, 2011 6:45 pm
Rickmeister
Rickmeister
I had the same grief when I first got the K. Ready to pull the whole air box apart (hours of work!) There are four clips that hold the top and bottom bits together. Undo the clips and the airfilter simply slides out.
I forget if the radiator hose needs to be removed.
Rickmeister.
3Back to top Go down   Changing air-filter Empty Re: Changing air-filter Tue Nov 29, 2011 7:12 pm
krambo
krambo
As Ulrich_Grabau suggests above - it is a very tight squeeze though and the spring clips are a sod to get back on - good luck Wink
"Aut viam inveniam aut faciam." Changing air-filter Uk-bmw12
http://www.its-personal.net
4Back to top Go down   Changing air-filter Empty Re: Changing air-filter Wed Nov 30, 2011 1:19 pm
ReneZ
ReneZ
Problem is that the isolation bulkhead rubber pushes the top of the airbox down. UIn order to slide the filter out you need to undo the (IIRC 3) clamps and lift the top part just a tiny bit, then the filter slides out. If you have a spare one it'll become clear. Note the indications regarding top (and front??).
Rene
BMW K100 - 1985 (0030029) Scotland Changing air-filter Rain
5Back to top Go down   Changing air-filter Empty Re: Changing air-filter Wed Nov 30, 2011 3:06 pm
zonenfeile
zonenfeile
by the way - just cross the border south a few km (Neumünster, Treia ) it is not that far
a lot guys know to handle the below mentioned prob!
have a look on the lower part for the clips pos 14
You remove the Upper part to the right side
if it´s open:
have a real honest look to the rear side of the throttles
everything ! made of rubber is usualy worn
inkl fuel tubes
that causes air leaks and poor running
I know - you only want to change the filter but I bet .... if that has not been done in the past
all needed spares for that : you find there , german but no. & links are usable
This pics is an 1100 K but that doesn´t matter, the drawings are K100 16V
Changing air-filter 10
Changing air-filter PICT0224
6Back to top Go down   Changing air-filter Empty Re: Changing air-filter Wed Nov 30, 2011 3:23 pm
krambo
krambo
Now there is a sight that I was hoping not to see again for some time lol Wink
7Back to top Go down   Changing air-filter Empty Re: Changing air-filter Wed Nov 30, 2011 7:50 pm
krambo wrote:Now there is a sight that I was hoping not to see again for some time lol Wink
THats a K1100 and are even more of a nightmare than a K100. More tubes to leak and fall off.
8Back to top Go down   Changing air-filter Empty Re: Changing air-filter Wed Nov 30, 2011 9:28 pm
krambo
krambo
You forget K Freak - I also have a 1993 K1100LT in the stable ! Mind you, I did think it looked a little different from my old K100RT battlebus Wink
9Back to top Go down   Changing air-filter Empty Re: Changing air-filter Thu Dec 01, 2011 5:48 am
zonenfeile
zonenfeile
Ok - some more parts bit you ´ve got to order 4x intake mainfold
the 4V ´s only need O-Rings
but:
doing the job once after 20 years....
4v models: 1 day incl complete sychr. , cigaretts, grill, beer
10Back to top Go down   Changing air-filter Empty Re: Changing air-filter Sat Dec 03, 2011 4:57 am
ReneZ
ReneZ
Sounds like a proper wrenching job Laughing
Rene
