1Back to top Go down   Need another LED? Empty Need another LED? Thu Aug 03, 2017 8:44 am
With a K1100RS belly pan you really need a flashlight to check the oil sight glass. Unless you add an LED!  (Tapped into a switched power source so all I need to do is turn the ignition on.)
Need another LED? Oil_si10
2Back to top Go down   Need another LED? Empty Re: Need another LED? Thu Aug 03, 2017 9:45 am
Another darn light to clean......I did wonder about putting one inside!!
3Back to top Go down   Need another LED? Empty Re: Need another LED? Thu Aug 03, 2017 10:44 am
I did that with both of my bricks with belly pans.  Saves having to find a flashlight.  I used LED license plate lights.
http://www.ebay.com/itm/4PCS-White-LED-SMD-Motorcycle-Car-License-Plate-Screw-Bolt-Light-lamp-bulb-/122498942745?epid=882899693&hash=item1c85818719:g:DkgAAOSwcaFZGqTD&vxp=mtr
4Back to top Go down   Need another LED? Empty Re: Need another LED? Thu Aug 03, 2017 11:58 am
I just use a BA9S LED bulb.  Only one wire (12V) to run that way since the little mounting bracket I make serves as the ground.
Need another LED? Oil_si11
