1Back to top Go down   Idling problem Empty Idling problem Wed Apr 08, 2020 3:38 pm
PiotrK100
PiotrK100
Hi there again
There is the movie that will show everything better that thousand words:
https://www.youtube.com/watch?v=8uWburs0V24
I have no idea what can cose that problem because linkage has a free play, nothing clogg the free movement. Looks like a spring is not closing baterfly (but all springs are ok) but how? All is ok.
I'm sure the explanation must be very simple but looks like I'm to stupid to find one. That is why must be supported lol!
http://www.xenum.pl
2Back to top Go down   Idling problem Empty Re: Idling problem Wed Apr 08, 2020 4:26 pm
moriarti
moriarti
Make sure  the Choke/ fast idle cable is not stuck and pulling/holding the throttle open.
3Back to top Go down   Idling problem Empty Re: Idling problem Wed Apr 08, 2020 4:31 pm
PiotrK100
PiotrK100
moriarti wrote:Make sure  the Choke/ fast idle cable is not stuck and pulling/holding the throttle open.
Done already, a lot of free play.
http://www.xenum.pl
4Back to top Go down   Idling problem Empty Re: Idling problem Wed Apr 08, 2020 4:34 pm
Things to try:
It may be the TPS holding it open.
Also lube the throttle gears in the throttle perch. (I get rid of the old grease and use spray silicone instead.)
Try adding some slack where the throttle cable leaves the throttle perch.
Make sure that the grip rubber is not rubbing against the throttle perch. (or bar end if there is one)
Spray some silicone grease in the TB springs.
5Back to top Go down   Idling problem Empty Re: Idling problem Wed Apr 08, 2020 4:41 pm
nino
Hi Piotr, few years ago you posted a engine noise  problem on this forum, but never finished. What happened, did you solve noise. How?
6Back to top Go down   Idling problem Empty Re: Idling problem Wed Apr 08, 2020 5:05 pm
PiotrK100
PiotrK100
duck wrote:Things to try:
Will try TPS but just made adjustments and looks ok.
Believe me all linkage, places where linkage goes were several times lubricated and everything plays free. Only the throttle behaves as the spring did not close butterfly completely. I think I should looking for problem in there, but TPS also looks somehow reasonable
http://www.xenum.pl
7Back to top Go down   Idling problem Empty Re: Idling problem Thu Apr 09, 2020 7:23 pm
Snod Blatter
Snod Blatter
Came here to say make sure there really is free play in the cable, when I first got my K I couldn't figure out why I had to set the cable to have loads of slack before the revs would fall quickly down to idle and it was because the gear wheel with the chain on it was heavily worn, which adds a lot of slack to the movement.
Also, some kind of grease (or I'd start with light oil) on the TB springs is easy enough to try.
Do the revs fall back to idle speed quickly?
8Back to top Go down   Idling problem Empty Re: Idling problem Thu Apr 09, 2020 8:37 pm
Make sure the cable is not jamming in the cable channel where it attaches at the TB's.
9Back to top Go down   Idling problem Empty Re: Idling problem Thu Nov 14, 2024 4:20 pm
Rolf E
Rolf E
This thread is there already with just about the same title. So, I'll just latch onto this one. Unfortunately the YouTube video is no longer available but my issue is the following:
The bike will idle perfectly. Then after a while at a traffic light start to idle slower and slower until it stalls. Sometimes it will even idle a little faster. This happened after getting the K75s into shape.
I purchased the K75s in Cape town. It was idling ok and was running well. But the trip home to Pretoria was costly with a fuel consumption of 14km/l. (Just more than 220km on a tank) It got a good dose of injector cleaner and valve ease along the way. In many ways it needed a clean-up, service and repairs. (even a welsh plug) The handle bar was bent and eventually I found out that the triple clamps were not true too. Accident ..... fortunately I have a doner K75s.
After all the work, I did the 3600km eastern Cape trip, and the bike performed well, except for the idling problem and the front forks. The fuel consumption was steady 19km/l.
The TPS was not set correctly, which I corrected, checked compression, valve clearances, plugs, water temp sensor, cleaned the TB and checked for air leaks and the Z breather pipe. Checked the AFM resistances as per the info I found on the forum. I changed the injectors (Bosh EV14 multi port) because I thought that they may have something lodged or loose in them changing the fuel quantity. In the mean time had the original injectors tested and they a are good. Fuel pressure and delivery is good too.
Now I am at a loss of ideas or options and am hoping some light may come from the forum?
Greetings Rolf
1991 K100RS 16V VIN: K100RS 0200487 Engine# 104EB 3790 2230 Charcoal 166000km
1991 K100RS 16V VIN: K100RS 6408910 Engine# 104EB 2290 2130 Pearl White 217000km
1991 K100RS 16V VIN: K100RS 0200487 Engine# 104EB 1091 2053 Pearl White 77000km
1989 K75s VIN: K75s 0108752 Engine# 753EA42894104
https://www.teuntin.co.za
10Back to top Go down   Idling problem Empty Re: Idling problem Today at 12:12 am
Rolf E
Rolf E
Yeh... Problem solved.   lol!
The only thing that I could still think of was that there must be some fault with the air flow meter. So I started with opening and measuring a spare unit that was dirty (came in a box with spares) and checking it according to Beamer's thread on air flow meter restoration. Everything looked fine, I cleaned the unit and at the same time also the air bypass. Doing so I checked the turns on the air screw before taking it out. The O-ring on this unit was perished . . . . so let me check the O-ring on the unit on my bike and compare the number of turns it is out.
Ha ha ha ... the air bypass screw on my air flow meter was turned tightly in the closed position. Since I don't have a CO analyser I checked on the forum what the +/- turns can be and this confirmed that the 4 3/4 turns on the spare unit was in line. I turned mine out 4 1/2 turns and bingo, the bike is idling well after resynchronising the TB. It is amazing that it actually still idled.
What a fool I am to not have checked this from the beginning and assuming people don't fiddle there and the CO must be sort of right by checking the condition and colour of the spark plugs.   Idling problem 167893
Assumption is foolish
Trust is good
Check is better
Idling problem 723598
11Back to top Go down   Idling problem Empty Re: Idling problem Today at 1:27 am
bad boy
bad boy
:tu1:well done, mate!
Thank you for sharing the solution of this puzzling problem.
PS:
you wrote: 'Assumption is foolish'
the other day, I heard that one from a teacher:
ASSUME
makes an
ASS of
U and
ME
BTST:
I've ran into more than one difficult situation myself just by assuming I knew what the problem was.
And I had to say this classical quote to myself in the end:
https://youtu.be/0srO4LTzVTE
Rolling Eyes
Last edited by bad boy on Sun Nov 17, 2024 1:41 am; edited 1 time in total (Reason for editing : PS)
Cheerz, David
Idling problem 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
