1Back to top Go down   K100RT issue Empty K100RT issue Sat Sep 14, 2024 6:31 pm
agbikeadv
agbikeadv
Hi,
Purchased an 87 K100RT a few months back which had sat idle for unknown years and I am finally getting around to getting it back on the road. Is Ex NSW Police bike and was used at Queanbeyan. 99k on the odometer.
Thankyou
Tony
Last edited by agbikeadv on Sun Sep 15, 2024 6:24 pm; edited 2 times in total (Reason for editing : Wrong intro)
2Back to top Go down   K100RT issue Empty Re: K100RT issue Sat Sep 14, 2024 9:08 pm
The fuel pump will only keep running when engine revs are above 711rpm and when the start button is pressed, it will then continue to run for 1.5 seconds after the start button is released if the engine has not fired.
3Back to top Go down   K100RT issue Empty Re: K100RT issue Sun Sep 15, 2024 9:38 am
WelKome. It makes sense to only introduce yourself here, then ask questions in the appropriate "troubleshooting" section.
4Back to top Go down   K100RT issue Empty Re: K100RT issue Fri Oct 04, 2024 10:07 am
Bernie_K100
Bernie_K100
Hi Rick,
K100RT issue 177912 to our community!
Bernie
5Back to top Go down   K100RT issue Empty Re: K100RT issue Tue Oct 08, 2024 9:11 pm
hi Tony
im just up the road in Glen Innes , if you need a hand with something
there are a few of us up this way in guyra  etc
regards
charlie
6Back to top Go down   K100RT issue Empty Re: K100RT issue Wed Oct 09, 2024 6:50 am
K100RT issue 177912
