1Back to top Go down   Side panel securing arm repair/bodge Empty Side panel securing arm repair/bodge Wed Nov 01, 2017 5:31 am
audibob
audibob
If you have ever managed to break a side cover arm , get a plastic flymo blade securing tool and cut off the hook at the end.
My arm broke in just the right place to provide a base for the " new arm " to fit into.
The radius was very close to the original .
Of course this is only likely to happen when you replace the securing grommets,  jeez  you have to be real careful trying to pry the cover off ....
This probably falls into the " White cable tie " category , but hey ho ......  Side panel securing arm repair/bodge 652573
Bob
Side panel securing arm repair/bodge 20171013
Side panel securing arm repair/bodge 20171012
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
good work
white cable ties ..?
Side panel securing arm repair/bodge 44271
I have three of those Flymo thingies in my shed.....now why on earth did I ever think they would come in useful some day. Both tabs on the RT are broken off.....
I didn't even have a K when I got the first two.....
Is there a correlation between having a Flymo and a K?????
For the record my Flymo does NOT have white cable ties....but I do have white cable ties.
glennpm
glennpm
This is my fix. The white cable tie broke so now I have the "proper" UV resistant black one :-)
Side panel securing arm repair/bodge Dscn2717
It is easy to stick my forefinger under the cover and slip it over the post.
Regarding the rear post, JB Weld epoxy to the rescue.
Side panel securing arm repair/bodge Dscn2716
Regarding, "Of course this is only likely to happen when you replace the securing grommets,  jeez  you have to be real careful trying to pry the cover off ....", I lube the tit on the cover with silicone grease. When I remove the cover, I put fingers underneath and then brace the outside with my other hand to control things.
Glenn
