1 intermittent no start on K100 Thu Jul 25, 2024 6:55 pm
letsgetpractical
I have been having an intermittent no start condition on my K100. I discovered if I wiggled the wiring harness going to the fuel injectors it will start and run fine. Soooo, I already inspected the externals of the harness and it looks fine with no breaks or open spots. So I suspect its at a connection. This harness combines with another harness and goes to the ECU? unit. So I want to check the connection there. It seems to be secure and has a screw holding connection in place. I want to disconnect this connection and inspect. Are there any precautions I should take other than disconnecting battery? I dont want to inadvertently damage something and I know the electrical components can be tricky. Thanks
