1 Early 85 K100 Vacuum Switch Wed Nov 28, 2012 2:11 am
ibjman
Both my street 85 K100rs and my parts bike RT are equipped with the vacuum sensing switch mounted on the inside of the fuel rail and plumbed to the vacuum port on the #1 throttle body. I understand that it's signal goes to pin #15 of the Ignition Module. I also understand that it was "discontinued" by the end of the 1985 model year run.
It appears to be an "on/off" switch.
What is it's function? What will occur if it fails or works incorrectly?
I've read a lot of hours in these forums and I've not been able to locate the information. The FI troubleshoot section shows it clearly on pin #15 of the Ignition Module but makes no mention of its values or reasons?
