1Back to top Go down   no lights no start Empty no lights no start Wed May 29, 2024 1:09 am
mmgee123
mmgee123
(1988 bmw k100) not 100% sure what happened bike was starting and running fine and then i tried to wire up an aftermarket tail light and now suddenly i have no lights when i turn the key and it won’t even attempt to start, i charged the battery and it’s still doing it. any tips?
2Back to top Go down   no lights no start Empty Re: no lights no start Wed May 29, 2024 1:10 am
firstle
firstle
put the old light back on ?
3Back to top Go down   no lights no start Empty Re: no lights no start Wed May 29, 2024 6:39 am
You've most likely cross-wired the new tail light and shorted one or more fuses. If the new tail light is LED then it's possible you've fried that as well.
4Back to top Go down   no lights no start Empty Re: no lights no start Fri May 31, 2024 1:50 pm
mmgee123
mmgee123
Dai wrote:You've most likely cross-wired the new tail light and shorted one or more fuses. If the new tail light is LED then it's possible you've fried that as well.
i didn’t know cross wiring was an issue, i was testing the different wires by taping them together and trying to use the blinker. it definitely sounds like this is my issue thank you!
5Back to top Go down   no lights no start Empty Re: no lights no start Fri May 31, 2024 5:26 pm
Don't let the smoke escape.
Crying or Very sad
6Back to top Go down   no lights no start Empty Re: no lights no start Fri May 31, 2024 11:57 pm
mmgee123
mmgee123
Two Wheels Better wrote:Don't let the smoke escape.
Crying or Very sad
what? lol
7Back to top Go down   no lights no start Empty Re: no lights no start Sat Jun 01, 2024 10:06 am
Crying or Very sad
what? lol
Smoke is the thing that makes electrical circuits work. We know this to be true because every time one lets the smoke out of an electrical circuit, it stops working. This can be verified repeatedly through empirical testing.
This phenomenon was originally observed and proven by Joseph Lucas.
8Back to top Go down   no lights no start Empty Re: no lights no start Sat Jun 01, 2024 10:42 am
When asked how a man is meant to drive home with often-failed Lucas electrics, rendering headlamps useless, it was reported that Lucas' reply was,
"A gentleman does not motor about after dark."*
-Joseph Lucas, aka The Prince of Darkness
*I did not verify with Snopes.
Wink
9Back to top Go down   no lights no start Empty Re: no lights no start Sat Jun 01, 2024 1:24 pm
firstle
firstle
rubbish
10Back to top Go down   no lights no start Empty Re: no lights no start Sun Jun 02, 2024 11:19 am
firstle wrote:rubbish
Yes, Lucas stuff surely is.
11Back to top Go down   no lights no start Empty Re: no lights no start Sun Jun 02, 2024 12:46 pm
firstle
firstle
there from the beginning when few knew how to maintain dynamos etc let alone carbide , you are ill informed or just plain stupid
lucas-1897-inside-cover
12Back to top Go down   no lights no start Empty Re: no lights no start Sun Jun 02, 2024 1:07 pm
It is honourable you feel the need to defend the company but there is no reason for name calling.
It is not personal affront. Please restrain yourself.
13Back to top Go down   no lights no start Empty Re: no lights no start Sun Jun 02, 2024 1:34 pm
firstle
firstle
ok , what personal experience have you with a lucas product i maybe able to help , or are you just spreading something you have been told etc . heres another one for you , elvis is alive and living on the moon
14Back to top Go down   no lights no start Empty Re: no lights no start Sun Jun 02, 2024 2:02 pm
Despite all of the grief that Lucas gets, I owned a high mile beater MG while in college and the Lucas electrics were the one thing that never failed.
15Back to top Go down   no lights no start Empty Re: no lights no start Sun Jun 02, 2024 4:01 pm
The real problem with Lucas electrics on motorcycles was the lack of a dedicated earth wire. There you have a miserable six volts trying to fight its way back through thick greasy headstock bearings with no guarantee of a good earth connection... add poor maintenance and headlight reflectors that have lost most of their reflectivity through age and no wonder that the available lighting was so poor most of the time.
It's also the reason why I always add a dedicated earth loop to any wiring harnesses I make, whether there was one originally or not.
16Back to top Go down   no lights no start Empty Re: no lights no start Sun Jun 02, 2024 6:54 pm
I never owned a vehicle with Lucas parts, but my son owned an early 70's Spitfire, a brother-in-law owned a couple MGBs and MGAs, and I had a female acquaintance who owned a 1968 MGB in the late 60's.   I watched all of them struggle with starters, generators, ignition coils and voltage regulators, especially voltage regulators that seemed to delight in frying batteries.
I know my son didn't have a reliable vehicle until he replaced the wiring harness with one he built himself and several of the Lucas components with aftermarket.  Until that point, there were several occasions when I had to tow his non-running car home.
In fairness, maybe the cars built for the North American market were built with parts manufactured to a lower standard.
17Back to top Go down   no lights no start Empty Re: no lights no start Mon Jun 03, 2024 1:06 am
firstle
firstle
no difference in the item just a simple lack of understanding for how things work , its very very common
cutout
delete duplicates
18Back to top Go down   no lights no start Empty Re: no lights no start Mon Jun 03, 2024 6:10 am
no lights no start 44271 That's almost not fair. Add to my list people who used to abuse the adjusting screws to try to get more voltage out of the regulator than it could safely deliver. Result = burnt-out regulator coils. Lucas' automatic regulator was a distinct improvement over the manual one.
19Back to top Go down   no lights no start Empty Re: no lights no start Mon Jun 03, 2024 9:21 am
Post WW2 Lucas suffered from the usual problems as did many UK manufacturers in that they had old production lines that were either worn out from heavy use making military stuff or rusty old junk that sat for 6-8 years where as Bosch had new factories because the old ones did not exist any more. The bike manufacturers had similar problems and didn't recover.
I have had several bikes and cars with Lucas electricals and they weren't the best but for the time were mostly OK.
20Back to top Go down   no lights no start Empty Re: no lights no start Mon Jun 03, 2024 12:32 pm
firstle
firstle
more volts for the 6v or 12v systems , adjusting the cut out incorrectly will result in damage (over charge)  , which year are we talking and on what ? have you a regulator model in mind which has been altered to this extent . i still run 6 and 12 volt systems dynamo , 6volt lights are a lot better now with the led bulbs but i still run filament as i think it suits the bikes better more in keeping . lucas mag/dyno
21Back to top Go down   no lights no start Empty Re: no lights no start Mon Jun 03, 2024 1:45 pm
Sorry Craig - I'm not sure if you're talking to me or Rick?
