1Back to top Go down   Pass the hammer. Empty Pass the hammer. Fri Mar 11, 2011 6:36 pm
Comberjohn
Comberjohn
Need a bit of advice about the best way of removing allen bolts or screws.
I'm having difficulty removing one of the bolts which clamps the fork leg in the lower triple tree. Seems to have seized in the aluminium. Also trying to remove the smaller bolts that hold the floating disc onto the front wheel.
Afraid of rounding off the bolt holes.
What's the best method? Heat? Would a gas blowtorch be sufficient?
Or what about an impact driver?
Suggestions please.
2Back to top Go down   Pass the hammer. Empty Re: Pass the hammer. Fri Mar 11, 2011 7:29 pm
I would avoid using an impact driver because it could tear off the thread..
First think to do is to is to hit the screw with a good blow (Use a punch that fits into the hex of the head). sometimes a good blow will be enough to 'unseize' the thread and you will be able to slack the screw. If you are successful with this method, slack the screw by 1/8 to 1/4 turn and then poor some penetrating oil over night.
If this doesn't work, the torch is the second option. You will have to give a very quick heat to the aluminum and then a good blow on the screw. Aluminum expands quicker and to a higher ratio than steel. The reason for a quick heat is to expand the aluminum without expanding the steel.
Pass the hammer. Frog15Pass the hammer. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Pass the hammer. Empty Re: Pass the hammer. Fri Mar 11, 2011 8:45 pm
Hi,
I would suggest the use of penetrating oil made from a 50% mix of acetone and ATF and let it soak. It sometimes takes an overnight soak and then as Bert says a couple of good whacks to break the hold of the corrosion which has probably locked the screw in place.
4Back to top Go down   Pass the hammer. Empty Re: Pass the hammer. Sat Mar 12, 2011 5:00 am
i have always found it usefull to try tightening before loosening when finding a stuck bolt ........ after tightening ..give the head of the bolt a little whack with a hammer ...often the retensioning of the bolt stores some energy and then the whack will release the threads a touch ......enough to start undoing at least .......just a thought....
