tinyspuds
tinyspuds
Afternoon all,
Title was a bit blunt wasn’t it? I want to put carbs on my K100 (lightly modified RT with sidecar).
Inviting suggestions for suitable Carbs, Configurations, and Manifold solutions (Your reasoning would be good too, so that I can sound very knowledgeable when I’m accosted at all the rally’s I will reliably attend).
I have no preconceptions beyond thinking that a performant 1 into 4 solution would be both heroic and beyond my maths and practical abilities (unless you know better).
I am hoping to still have a safe/usable (UK M’way) outfit at the end. I don’t expect to save fuel or improve peformance.  I have no better reason for doing it beyond I want to, I have the down time and I expect it to be fun.
I don’t want to spend a fortune or hire a team of engineers.
I expect to delete or relocate to the sidecar:
Radiator, Fan, All things EFI, Battery, Maybe OEM HES, Possibly tank and fuel pump and FPR.
I expect to have a working test bed built from those boxes of bits Kpox promised me I would need.
In return, I’ll document the progress of any actual building that goes on. Everything I’m fed back will be collated and organised for publication at the back of the site.
I’m aware its been done before, and I’m not above nicking anyones ideas directly but I also thought it might be interesting to poll insights from a wider base that also know stuff but would otherwise never dream of doing this particular thing.
I’ve been down for 3 months. I’ve binged (and conquered):
- West Wing
- Star Gate SG1
- Star Gate Atlantis
- Deep Space 9
- Time Team
- Voyager
- Yes Minister
I expect a further 3 months that starts with a relocation to the Shed and a major reorg in preparation for the Big Project. Please consider your ideas as an act of Mercy.
TIA, Stu
tinyspuds wrote:I’ve been down for 3 months. I’ve binged (and conquered):
- West Wing
- Star Gate SG1
- Deep Space 9
- Time Team
- Voyager
- Yes Minister
Take on Battlestar Galactica if you haven't already.
Yes, carbs have been fitted to K100 before.
And the average result is...not very enthusiast. Some tried to fit Mikuni carbs ramp from a Yamaha Genesis engine to keep a quasi vertical intake, some used a common manifold with a car carb.
And some fitted Keihin CR expensive carbs.
Don't expect a better output, but a bigger input with a lowered MPG.
And in your particular case, think about the particularities of a side car: the motorcycle carbs are design to cope with gravity and centrifugal forces that are always parallel to the motorcycle.
On a sidecar, this does not applies: gravity and centrifugal forces are not coherent as you can't tilt.
This caused big problems of fuel starvation on racing sidecars, and led to fit twin bowls, pretty high to sole this issue.
I'd be glad to try carbs on a K100, but on a K100 sidecar, I'm convinced that keeping a fuel injection is the best option.
If you relocate the fuel tank, think about creating a pit for the fuel pump at the bottom, and some walls to keep it always under the fuel level in curves!
I'm often suffering this issue on my K's rigs.
But if you want to use carb, so choose a car carb, with a bowl designed to work in a flat position.
That was my 2 cents!
That fills our fairest day.
firstle
firstle
if you want a easy life and for the conversion to work , single SU every time , get a old type of the Austin and you can run at most angles .
Suzi Q
Suzi Q
Single SU would be my (laughably ignorant) suggestion, because that's what knowledgeable turbo people use. The issue would be the 4-1 manifold. If you could conquer that, then a single carb has got to be the thing.
tinyspuds
tinyspuds
- West Wing
- Star Gate SG1
- Deep Space 9
- Time Team
- Voyager
- Yes Minister
Always good to hear from Vermont; Home of the ‘Winters that binge watching was invented for’ Smile. We talking Classic or the modern remake?
tinyspuds
tinyspuds
Ooh! That’s interesting.
tinyspuds
tinyspuds
firstle wrote:if you want a easy life and for the conversion to work , single SU every time , get a old type of the Austin and you can run at most angles .
I like the single carb idea because it looks cool (so what, I’m shallow) and also because of the workspace it creates as opposed to shoehorning a set of 4.
tinyspuds
tinyspuds
Suzi Q wrote:Single SU would be my (laughably ignorant) suggestion, because that's what knowledgeable turbo people use. The issue would be the 4-1 manifold. If you could conquer that, then a single carb has got to be the thing.
The thread so far (thanks for the nudge) has made me realise that a car solution does provide access to a much larger talent pool iro the gas flow calculations. As for being laughable, you’ve come on a lot since your time in the German bunker during the height of Madass Madness.
The modern remake if you can get passed the first six or so episodes. It's much darker than the original and confusing, but once you start to figure out the storyline it gets pretty damn good.
I never have viewed the original but Battlestar's remake almost got us all the way through mud season once.  Carburetor recommendations / thoughts please 112350
firstle
firstle
i try to fit single SUs to any old cars i get , also fitted one to a 1958 triumph and it was the best running/starting triumph i had , just fitting one to a midget , if you go down this route take some pics as i maybe interested in trying also , having said that the fuel injection on the Ks i have had has been faultless , i did try a single carb on a goldwing (solex) and it was rubbish so went back to standard carbs
Suzi Q
Suzi Q
So here's a daft one.
The Mini cylinder spacing must be similar to the K, because fifteen million K's have been slaughtered so's their heads could be grafted onto asthmatic old rustboxes. Why not try the reverse route? - maybe a 4-1 inlet manifold from a mini could be made to........jeez I can't believe I'm typing this nonsense...Carburetor recommendations / thoughts please 72
Well that's your spring project sorted, Chris. Let us know how you get on Carburetor recommendations / thoughts please 44271
tinyspuds
tinyspuds
Suzi Q wrote:maybe a 4-1 inlet manifold from a mini could be made to........jeez I can't believe I'm typing this nonsense...Carburetor recommendations / thoughts please 72
Funnily enough, that is where I started. S
tinyspuds
tinyspuds
firstle wrote:i try to fit single SUs to any old cars i get ….
Hi F, Thanks for these feedbacks.
Would be interested in understanding the form here. The SU was once the SI unit of car carbs. I imagine that there are thousands of 1:4 inlet manifolds designed to accept a single SU mounted vertically and the same number again horizontally (my tech speak on this subject will veer towards Early Primate).
Do you track down a carb of the flavour required considering:
mounting orientation,
engine capacity,
Rev characteristics
Venturi capacity,
Engine interface diameter (as it relates to the bikes inlet size).
Do you then track down a manifold that is close to spec/config and (have someone skilled to) modify it to fit the physical application
Or order one custom made, Where do you find such people?
Thanks and kind Regards,
Stu
If you can tune any carb to fit the engine specs about AFR and these sort of issues, the manifold is another question.
First: because of the geometry of the K engine, any manifold design for a single carb will suck because it will create angles that will limit the gas speed into the hoses.
The inner diameter, the changes of inner diameter, the length (and equal lenght) of the intake hoses are very important, so is the lenght before jonctions of the hoses if you use a single carb. As for the exhaust, this needs to be tuned finely to prevent bad resonances. Using a car manifold, designed for an engine that runs at low RPM is not necessarily adequate with a motorcycle engine with twice max RPM.
You should search for engines with the same geometrical specs, and similar perfs to borrow the manifold.
Or create a new one from scratch, welding hoses. The most difficult may be to achieve a manifold with equal lenght of the 4 intake hoses.
Another option would be to use carbs with top down bodies, designed for flat engines, as VW flat 4 airheads or Alfa Romeo boxers. Better design, but short intake is mandatory.
It's an interesting project!
firstle
firstle
this one is going on the midget later this year with the gearbox od change
https://ibb.co/LPx6Wvp
 "Using a car manifold, designed for an engine that runs at low RPM is not necessarily adequate with a motorcycle engine with twice max RPM" ........... this is where the SU wins , it has no fixed mechanical mixture position , the problem maybe finding the correct needle and spring , the carb will handle high rpm and the load , not all out performance carb (unless dashpot is removed) but well suited for road use .
tinyspuds
tinyspuds
jbt wrote:Another option would be to use carbs with top down bodies, designed for flat engines, as VW flat 4 airheads or Alfa Romeo boxers. Better design, but short intake is mandatory.
All valid points JBT. My preliminary reading was beginning to seem like manifold design might be a bit more forgiving on the SU vs a bike carb. But I’m not convinced.
2 carbs into 4 at least only needs a pair of matching manifolds, that said: I’m being told it is common place for 1 into 4 so I’m going to keep researching.
No question that the downward dog approach of the flatties is neater but boxers are a bit of a cheat because they basically use a matched pair with the carb at the centre. As you say ‘Interesting’ (esp. when the comprehension level is as low as mine).
tinyspuds
tinyspuds
firstle wrote:this one is going on the midget later this year with the gearbox od change
Bingo First Person,
Thats the pic I’ve been searching for. Do you imagine that the main duct gets a little bigger (mathemmatical expression) internally towards the two ends to provide for the extra juice/distance or is the SU just not that fussy?
Coupled with a downward feeding (you’d think they’d have a name for those) SU would get the job done perhaps.
firstle
firstle
the SU is just not that fussy ,  Carburetor recommendations / thoughts please 112350
Jordan53
Jordan53
I've had a little experience with SU, mainly with cars.
For sidecar use I would consider using an HIF type, that has a concentric float configuration and should be more consistent when cornering and braking.
SUs are nice and simple, the main challenge being to find an appropriate needle and spring.
I found this webpage helpful:
https://www.classicminidiy.com/technical/needles
The comparison chart is active, allowing comparison of needles live online.
A good resource is other people who have tried and reported on their experiences with needle selection on similar vehicles to your own.
You just have to find them. Smile
An air/fuel ratio kit based on an EGO sensor might be useful too.
Lots of spare time would help!
1989 K100 RS
VIN: xxx0149621
firstle
firstle
 HIF type very nice carb but maybe limited for the angle it can be used at , cornering and braking same as when fitted to a car , i like the earlier type which you can rotate the float bowl
Removing the plenum and air box is going to leave you with a massive air gap that the radiator can use to clear the air from the radiator, using a four into one inlet and single carby across the engine is going to put that carby in the radiators air flow. A good deflector would allow some cooler clean air to roll into the carby area and save any chances of a boil up. Truth be told you can choose any tank you like with a petcock when this decision is made. I've no idea how you would plug the injector holes. I suppose you can duct some of that hot air from the radiator into the chair, should make winter rides a peach for the pillion.
K75cster wrote: I've no idea how you would plug the injector holes.
Thread them but leave a ledge at the bottom. Use grub screws and o-rings which will force the o-rings to create a seal. You'd probably need to glue the grub screw in as a backup too. It's a job you'd need to do with the head on the bench to ensure that everything is seated where it should be.
Here Ernesto's engine. The result could be conforming to Dai's description.
Carburetor recommendations / thoughts please Screen12
Whoever did that had a better idea than mine. Threaded the holes, yes, but took the easier route of an o-ring under the caphead.
tinyspuds
tinyspuds
Thanks all for such a great level of engagement.  It occured to me that SU enthusiasts might have similar forums to us and equally keen interest in the unexplored.  There’s hundreds! I’ll do some analysis tomorrow and establish contact with a couple of likely candidate groups.
tinyspuds
tinyspuds
Laitch wrote:Here Ernesto's engine. The result could be conforming to Dai's description.
I had loosely supposed I would use some form of the exising arrangement e.g. injectors (maybe modified) and a bolted down rail, in the first instance at least during proof of concept testing.
tinyspuds
tinyspuds
Found my styling cues.
Carburetor recommendations / thoughts please Img_1310
firstle
firstle
another car engine in a bike , never that good imo
tinyspuds
tinyspuds
Does anyone have any decent drawing with measurements of inlet diameter and spacing?
Cheers.
K75 for sale in Ireland with a carb conversion. May give you some more ideas
BMW k75 for sale in Co. Meath for €1,500 on DoneDeal
Carburetor recommendations / thoughts please Ir-log10
 ;BMW; K1200RS Red
tinyspuds
tinyspuds
Ringfad wrote:K75 for sale in Ireland with a carb conversion. May give you some more ideas
tinyspuds
tinyspuds
Carburetor recommendations / thoughts please Img_1416
Carburetor recommendations / thoughts please Img_1415
No draughtsman, but drawings for the project were a must, so here are a couple. I’m using these as a path to informed conversations with fabricator/carb folk rather than a set of numbers I’d die for. TB manifold dimensions, for example, are sus due to deteriorating rubber of the example I measured. Whereas the detail around intake ports, spacing and centres were double checked by cutting out a cardboard template using my numbers.
The story continues.
