1Back to top Go down   tail light not coming on Empty tail light not coming on Tue Jun 25, 2024 5:49 am
mmgee123
mmgee123
hey everyone i have a 1988 k100 and i’m converting to a scrambler. i’m trying to wire a custom led tail light to mount on the frame, and i’ve wired up the ground wire and running light and it’s not coming on, i’ve checked all the fuses on the side (the 7 that are closest to the air box) and they’re all fine. i previously wired up the same tail light and fried it accidentally so i purchased a second one and now it isn’t wanting to work with me. any help?
2Back to top Go down   tail light not coming on Empty Re: tail light not coming on Tue Jun 25, 2024 6:17 am
Take it off the bike and test it on a battery. That will give you a go/no-go for the next stage.
3Back to top Go down   tail light not coming on Empty Re: tail light not coming on Wed Jun 26, 2024 10:50 am
The BMU controls power to the rear marker light.  Is your BMU remaining lit all the time even though you've engaged the front and back brake levers at least once since turning on the ignition?  If so, you might need to mod the BMU.  See Duck's instructions here: http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/bmu/bmu.htm
4Back to top Go down   tail light not coming on Empty Re: tail light not coming on Wed Jun 26, 2024 12:07 pm
If you're making a scrambler and using LEDs you can just ditch the BMU and wire as follows:
Gray/White wire from BMU connector to 12V+ of tail LED.
Gray/Green (front brake switch) and Grey/Red (rear brake switch) from BMU connector to 12V+ of brake light.
