1Back to top Go down   Introduction Empty Introduction Wed Dec 27, 2023 9:25 am
Nealchaykin69
Nealchaykin69
Hello! I just bought a 1985 K100RS and am turning it into a cafe racer. It is currently in many pieces as I get rid of the rust on the frame and clean and paint the engine. I look forward to talking and learning with everyone here. My current ride is a K1300R which I love dearly. Have a great holiday.
N
Introduction Img_1010
2Back to top Go down   Introduction Empty Re: Introduction Wed Dec 27, 2023 9:44 am
Introduction 177912
3Back to top Go down   Introduction Empty Re: Introduction Wed Dec 27, 2023 11:33 am
Bricklayer
Bricklayer
Welcome aboard from 1985 K100RS owner just south Lake Erie!
https://anthonymrugacz.net/
4Back to top Go down   Introduction Empty Re: Introduction Wed Dec 27, 2023 12:50 pm
bad boy
bad boy
hello Nealchaykin69
Introduction 177912
Cheerz, David
Introduction 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
5Back to top Go down   Introduction Empty Re: Introduction Wed Dec 27, 2023 1:34 pm
Welcome Neal Smile
Introduction Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
6Back to top Go down   Introduction Empty Re: Introduction Wed Dec 27, 2023 5:06 pm
Nealchaykin69
Nealchaykin69
Thanks for the warm welcome folks. Just got the wiring harness off the engine and will start the clean up soon. Fuel rail doesn't seem to want to come off...hmm.
N
7Back to top Go down   Introduction Empty Re: Introduction Wed Dec 27, 2023 7:21 pm
Nealchaykin69 wrote:Thanks for the warm welcome folks. Just got the wiring harness off the engine and will start the clean up soon. Fuel rail doesn't seem to want to come off...hmm.
N
That only has 2 10mm bolts, no other bolted or mechanical fixings, if its not coming off after you remove the bolts its only being held by sticky injector seals [O rings]. Nothing to break, just rock it a bit. You will be replacing the seals in any event.
Clean all the crud off first so you dont get it falling in through the injector holes. Vacuum cleaner job, I use one first to clean off around the seals but also to remove anything as I am removing the rail. The injectors are likely to come off with the rail but not always, there are no fixings to the rail, just the O rings.
8Back to top Go down   Introduction Empty O-rings Wed Dec 27, 2023 7:28 pm
Nealchaykin69
Nealchaykin69
N
Thanks Olaf, will spray a little wd40 on them before I try the rocking technique.  Very Happy
9Back to top Go down   Introduction Empty Re: Introduction Thu Dec 28, 2023 5:31 am
Hmmm. I'd dispute the 'nothing to break' statement. At the very worst the end of the injector will break off in the engine block but that's easily and carefully hooked out with a small screwdriver. I had two break on me recently while pulling a fuel rail out.
10Back to top Go down   Introduction Empty Thanks Thu Dec 28, 2023 8:07 am
Nealchaykin69
Nealchaykin69
Thanks Dai, I ordered 4 ‘new’ injectors. With my luck I’m sure I’ll break at least one and I’m sure at least one no longer works. Guy I bought it from never had it running but bike looks in great condition. 50,000km on it.
11Back to top Go down   Introduction Empty Introduction Thu Dec 28, 2023 9:04 am
davidaryun
davidaryun
Welcome Neal! Just curious, where did you order your injectors from? How much?
12Back to top Go down   Introduction Empty Re: Introduction Thu Dec 28, 2023 11:15 am
RS Rider
RS Rider
The injectors are attached to the fuel rail with clips. You'll have to remove them first before trying to pull them out of the rail.
Item #5 shown here.
13Back to top Go down   Introduction Empty Re: Introduction Thu Dec 28, 2023 11:36 am
Nealchaykin69
Nealchaykin69
davidaryun wrote:Welcome Neal! Just curious, where did you order your injectors from? How much?
Hey David, I got them on eBay. The cheap Chinese ones didn't have the correct part number even though they said they fit. Don't feel like rolling those dice. Rolling Eyes
Introduction Hfdsx10
14Back to top Go down   Introduction Empty Introduction Fri Dec 29, 2023 8:18 am
davidaryun
davidaryun
Thanks, let me know how they work!
15Back to top Go down   Introduction Empty Re: Introduction Fri Dec 29, 2023 8:34 am
Bernie_K100
Bernie_K100
Hi,
Introduction 177912 to our community!
Bernie
16Back to top Go down   Introduction Empty Re: Introduction Fri Dec 29, 2023 11:19 am
davidaryun wrote:Thanks, let me know how they work!
The best thing to do with FIs is send them to
https://www.mrinjector.us/
More on fuel injectors:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/fis/fis.htm
How to rehab fuel and air:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k75pa.rehab/k75parehab.htm#fuelair
17Back to top Go down   Introduction Empty Re: Introduction Fri Dec 29, 2023 11:40 am
Nealchaykin69
Nealchaykin69
Thanks David, I found out that there is a ‘diesel’ shop near me that cleans injectors to spec. Of course I heard that after I bought the new ones. I’ll keep it in mind if my other K bike (K1300R) needs it.  study
18Back to top Go down   Introduction Empty Re: Introduction Fri Dec 29, 2023 11:46 am
As a reminder, this is your Member's Introduction post. Any further tech discussion should be in a new thread under the appropriate heading. Why? It's cleaner for future research. It makes sorting and finding issues easier on the forum.
And that is not to say some of the best ever discussions don't come from bellying up to the bar and straight away striking up a good convo.
drunken
19Back to top Go down   Introduction Empty Re: Introduction Fri Dec 29, 2023 11:52 am
fishboy316
fishboy316
Welcome Neal from another 85 rs owner. Love mine!
20Back to top Go down   Introduction Empty New post Tue Jan 02, 2024 11:41 am
opa
opa
Welcome
santa
