1Back to top Go down   Type 1 Pannier Key #051. Empty Type 1 Pannier Key #051. Tue Sep 26, 2023 2:24 am
SSD (Paul) one of the K Kronies is in need of a key for type 1 panniers the key number is 051. any help would be appreciated.
2Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Tue Sep 26, 2023 8:13 pm
I'll touch base with a guy in Victoria that I know used to have a few of these and will post back if in luck on the #51.
3Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Tue Sep 26, 2023 8:42 pm
Appreciated Gaz, SSD''s a bit of a technophobe and doesn't do computers. Hence I've been appointed his secretary.
4Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Wed Sep 27, 2023 6:59 am
Received a reply from my contact in Victoria who notes that he still has about 40 of those keys but sadly no 051 amongst them.
Bad luck this time.
5Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Wed Sep 27, 2023 5:14 pm
Type 1 Pannier Key #051. 112350 Gaz thanks for trying.
6Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Wed Sep 27, 2023 6:17 pm
KevH
KevH
Hey I will check mine if they are the correct number maybe I csn get a couple cut??
7Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Wed Sep 27, 2023 7:13 pm
Thanks Kev. Even if somebody doesn't have a spare but has a 051 key that they could use to cut one would be great. I'm sure I could extract the cash from SSD. He has a K100, but we are modifying the Type 1 panniers  to go on his R100.
8Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Mon Oct 02, 2023 6:04 pm
Guys, the most difficult part of trying to “cut” one of the type 1 keys is getting or making a blank. There are various attempts listed here on the forum if you can find the threads. I’d be very surprised (but be delighted to hear) if you can find a locksmith who would attempt it.
I’ll have a close look at my Type 1 set of panniers later to see if it is likely that a Type 2/3 style latch could be fitted.
9Back to top Go down   Type 1 Pannier Key #051. Empty Key Mon Oct 02, 2023 6:48 pm
daveyson
daveyson
My local locksmith cut some for me, but I wasn't able to find the thread back which had more details, it might have been in the motobrick forum. The blank was slightly different but he was confident that it would work, and it did.
Scraping the bottom of the barrel now, the profile is possibly identical to another number with the groove faces reversed, anyway that's what I found with my key, which I think was 069.
 ~120,000 km
10Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Mon Oct 02, 2023 7:22 pm
Thanks fellas I might just get SSD to put a dirty big pad bolt on them.
11Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Sat Oct 14, 2023 12:23 am
Hi Guys, finally got around to looking at my various sets of BMW panniers regarding the locks.
What I refer to as Type 1 pannier locks are the ones with the lift up flap to access the key slot with the numbered keys that only move about 30 degrees one way or the other to lock/unlock which I have on my R80G/S. Examples below;
Type 1 Pannier Key #051. Img_5417
Type 1 Pannier Key #051. Img_5419
Having just measured the external dimensions of my K Bike touring pannier locks and the Type 1 locks, the footprint of each type is only a few millimetres different so I think the easiest solution would be to get hold of a set of these Type 3 pannier locks (example below) - drill out the rivets from the inside of the original locks and rivet the Type 3 set onto the pannier. If the panniers are to be used on a K Bike then there are threads around that describe how to modify the Type 3 lock to allow your ignition key to operate them. I had two K Bikes at one stage and modified the two sets of panniers that I had so that either bike ignition would operate the locks on either set of panniers.
Type 1 Pannier Key #051. Img_5416
Type 1 Pannier Key #051. Img_5418
Now you just need to find someone who is doing a cafe job on a K Bike because they won't use the panniers. There might also be a kind soul on this forum who has broken panniers who would be willing to part with the locks.
12Back to top Go down   Type 1 Pannier Key #051. Empty Re: Type 1 Pannier Key #051. Sat Oct 14, 2023 1:25 am
Thanks Gaz SSD has had a couple of leads and he is currently chasing them up.
