1Back to top Go down   Clutch cable Empty Clutch cable Wed Sep 20, 2023 2:20 pm
fishboy316
fishboy316
Hello, Hope all are well! Snapped a clutch cable yesterday on my 85 K100rs. Trying to figure out which cable to order. Was looking at EME and they were talking about the bars being high or low bars. I think these are low bars on my rs. (If not would hate to ride low bars) Just want to make sure to get the correct cable.
2Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 20, 2023 3:09 pm
Bricklayer
Bricklayer
On their website the cable and sheath length are listed. One could measure the old cable (or sheath) as a reference to be certain.
2 cents: Buy 2 and install both as I learned the cold hard way. Last time mine snapped I was in the French Alps on a pitch  black night and very cold outside. Installing a new one was not on my bucket list.
https://anthonymrugacz.net/
3Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 20, 2023 4:27 pm
fishboy316
fishboy316
Thanks bricklayer. That does not sound like it should be on a bucket list .... ever.
4Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 20, 2023 6:25 pm
firstle
firstle
tap the new one to the old and pull through  Smile
5Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 20, 2023 8:49 pm
Suzi Q
Suzi Q
The hardcore guys tape the new one next to the old one, and just swap them over when the old one fails. Always impressed me that  Surprised.
6Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 20, 2023 9:18 pm
fishboy316 wrote:Snapped a clutch cable yesterday on my 85 K100rs. Trying to figure out which cable to order.
The length discrepancy of EME's offerings compared with Max's is baffling to me.
Clutch cable 610153
7Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 20, 2023 9:45 pm
fishboy316
fishboy316
Suzi Q wrote:The hardcore guys tape the new one next to the old one, and just swap them over when the old one fails. Always impressed me that  Surprised.
Am actually contemplating doing that same thing.
laitch: will post the pic.
Thanks for the replys
8Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 20, 2023 10:53 pm
K75S & K100RS Bars - Clutch cable 32732324955 - 1510mm
Clutch cable K100rs.k75s.bars.tape.measure
K75 Std, K75C, K100 Std bars - Clutch cable 32732324955 - 1510mm (same as above)
Clutch cable K75C.Handlebars.Tape.Measure
"High" bars - K75RT, K100RT, K100LT - clutch cable - 32732324960 or 32731450215 - 1625mm
Clutch cable K100RT.Handlebars
9Back to top Go down   Clutch cable Empty Re: Clutch cable Thu Sep 21, 2023 6:28 am
The reason I was baffled was I was looking at the throttle cables. study Sad  All's right now that the fowl has landed.
10Back to top Go down   Clutch cable Empty Re: Clutch cable Thu Sep 21, 2023 2:27 pm
fishboy316
fishboy316
Thanks for the replies! I definitely Have low bars. Am ordering new today.
I think I will do 2 cables. I was very close to no clutch at all  in rush hour.
Thanks again folks
11Back to top Go down   Clutch cable Empty Re: Clutch cable Thu Sep 21, 2023 3:23 pm
One last thing: make sure you have the small felt piece that sits on the end of the cable next to the handlebar lever pivot and keep it greased.
12Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 27, 2023 11:53 am
Spare nipple needed, does not come with cable.
13Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 27, 2023 12:13 pm
Minor correction Olaf: it's the barrel that doesn't come with the cable. Damn stupid idea that was.
14Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 27, 2023 5:49 pm
fishboy316
fishboy316
Thanks for the info!
Is that a 10 mm barrel? What is the felt called? So far having a bit of a trouble finding one.
15Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 27, 2023 6:17 pm
fishboy316 wrote:What is the felt called?
I'd call it the pressed wool cable lubrication retaining device v1.0.
This is what MaxBMW calls it.
Clutch cable Scree274
16Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 27, 2023 7:34 pm
fishboy316 wrote:Is that a 10 mm barrel? What is the felt called? So far having a bit of a trouble finding one.
No. The wee b'stard is 8mm and peculiar to BMW. You may have to pay out at MaxBMW for one. Or two. Best get two because if you only get one it will feel unloved and at the first opportunity it gets, it will go and hide in the deepest darkest part of the garage where you can't find it.
17Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 27, 2023 7:45 pm
Suzi Q
Suzi Q
They're all living underground. They've joined up, there's a community of them down there  Shocked.
18Back to top Go down   Clutch cable Empty Re: Clutch cable Wed Sep 27, 2023 9:38 pm
fishboy316
fishboy316
Yes 2 for sure. If they get away in my shed they will NEVER be found! It eats small motorcycle (and bicycle parts for lunch) Very Happy
19Back to top Go down   Clutch cable Empty Re: Clutch cable Thu Sep 28, 2023 6:10 am
Is this part at Max what's being discussed here, or have I entered another phase of disorientation?
Clutch cable Scree275
20Back to top Go down   Clutch cable Empty Re: Clutch cable Thu Sep 28, 2023 4:14 pm
fishboy316
fishboy316
That is it Sir. is it supposed to be 8 or 10mm?
21Back to top Go down   Clutch cable Empty Re: Clutch cable Thu Sep 28, 2023 6:01 pm
fishboy316 wrote:
Laitch wrote:Clutch cable Scree275
Decision-making is tough, huh? Laughing  I tend to believe what I read at Max because I have no imagination. Sad
If by this time you don't have vernier calipers to measure the barrel/nipple holder, or to measure the barrel opening in the clutch hand lever, to decide which measurement will provide a secure fit neither binding nor disengaging, you're consigned to making a decision based on the number of confirming references for one measurement or the other—a strategy which I have occasionally needed to deploy and has been successful, so far. Laughing
In a life filled with consequential decisions, this one is a small potato if you have patience and reliable parcel delivery service in your area. Smile
22Back to top Go down   Clutch cable Empty Re: Clutch cable Thu Sep 28, 2023 8:16 pm
fishboy316
fishboy316
Agreed on the small potatoes. I believe it is a 10 as I early on had the cable bail
(Fell out of the lever) on me. It looked like the nipple was to small for the hole. Just realized I have another lever that I can measure. Never mind. Embarassed
