k100ing
k100ing
I'm looking for a left side battery cover panel to replace the cracked one on my 1985 K100RT, in silver. The piece below the seat.
I would take a set of two if you don't want to break them up.
Thanks!
https://instagram.com/k100ing
Case1234
Case1234
I have a pair in parts from a previous owner. Not silver though, one is blue and the other is just primer.
The LH unit has all the mounting tabs intact, the right looks like the slide on tab was repaired once.
I won’t make you buy both, but i will send you both if you’d like them. I have no use for them other than being “what if” parts for my RT.
k100ing
k100ing
Thanks Case, I’ll message you
1985 K100 RT, located in Kincardine, ON
1991 K100 RS, located in Las Vegas, NV
WTB: K100 Left Side Battery Cover, in silver (1985) K100in12
