1 Low idle after throttle body sync Mon Sep 25, 2023 4:45 pm
lucki
I should have left well enough alone!
Bike was running great! I had to fiddle.
Did throttle body sync, went well using two bottles. Set number three at turn and a half off bottom. But then idle around 800. Tried to adjust linkage but to get 1000 rpm the adjuster didn't have enough thread, as shown. Now number three cylinder adjusting screw, when I started, was three and a half turns off bottom. So to get idle up a bit I opened all screws another half turn.
Should I resync using three and a half turns off bottom for number three?
What's that little screw for near the cable?
Puzzled!
Puzzled!
