1 No electrical power Wed Jun 14, 2023 6:02 pm
OK1987LT
I have a 1987 K100LT. Sat for last 5 years. Retired since then and have been trying to get on the road again. Accomplished some component R&R. New Fuel injectors, new battery. Troubleshooting so far. Rebuilt starter, engine turns over. Then all of sudden no electrical power. Main issue is when battery is connected horn relay engages. No indication on any indicators; gear position, neutral indicator, lights, etc. Engine will not turn over. Engine ignition sw and starter/kill sw function correctly with VOM. I isolated the horn sw by disconnecting the connector below fuel tank. Horn relay still has power. I’m using the electrical diagram from the Haynes manual. I’m not a very good electrician so difficult for me troubleshoot. I need some help.
