gabriel
hi everyone
i am trying to remove the gearbox. i am having a lot of difficulties removing the alternator. i know it's not necessary to remove the alternator to get to the gearbox but i prefer to remove it so i can replace the bearing and rubber dampers? the allan screws wont budge and i think i am close to stripping the head on the screw on the right hand side (crankshaft) of the bike.
any suggestions would be appreciated.
i am also having difficulties keeping the bike upright and stable.
any suggestions.
thanks you
Give the head of the bolt a good solid whack with a punch and hammer.
Use a punch or even a piece of solid steel that is larger than the head of the bolt.
That jars a lot of the oxides waay from the thread and should let you get it out.
Use a couple of tressles and a bar under the rear of the frame.
yankeeone
Pull trans first , gives you more room, try a impact driver too break it free,
did my monkey nuts last weekend gabriell .....
k freak is right ....a good hard whack with a drift worked for me ...had 2 tough ones top left and bottom left were really giving me the run around ....
but i bought myself a couple of 3/8 socket adaptors to 6 mm allen keys in case i hit more in the future
oops almost forgot ....i put antisieze on the bolts whebn reinstalling ...casue i know ill be back there again ......(noticed oil vapours around the drive seals)
