1 Starting issue, low comp in all cylinders after head job Thu Jun 22, 2023 5:48 pm
sparkplug69
Hey guys,
Having some issues with my k100 from ‘85. This is my first fuel injected bike project and I am still learning.
Let me describe the situation:
I bought this bike with 68,000 miles on the engine. I bought it non-running and quickly realized she was do for a valve job and decking. I had that taken care of by professionals and have replaced many parts along with it. I have replaced the fuel pump and filter, the head gasket (evidently), miscellaneous tubing and cables and have had the injectors professionally cleaned.
I finished putting the bike back together today and cranked it over without the plugs in. I am getting really good spark, and what seemed to be solid compression. After doing more tests with cranking it with the plugs in, I did not get any sputtering or signs that she would start except for one very loud back fire that shot a flame 6 inches out of the factory exhaust.
I then tested for compression and realized that cylinder 1 read 60ish psi, cyl 2 50 psi, cyl 3 10 psi and cyl 4 virtually 0 psi.
Is it possible that I aligned my camshafts timing incorrectly or that my valve spacing is too tight? I followed the manual in setting those up and simply aligned the two cam gears up with their respective marks while the cyl 1 was at TDC. After reading a thread I think it is possible that I wasn’t perfectly at TDC (as truthfully I eyeballed it), but even then I would expect some sputtering. I also checked and the HEC cover was slightly off, I have now fixed it and centered it but that doesn’t not resolve the low compression issue.
NOTE: I did not feel any resistance after manually turning the engine over several times slowly before I ever tried to crank it. I do not think I bent a valve for that reason.
Any help would be greatly appreciated, looking for some guidance and thanks for your help
