1 Rear master cylinder replacements. Mon May 22, 2023 8:56 pm
I've managed to source some better rear master cylinder boots for the Chinese master cylinders. The cylinders require a groove machining for the boots lip to seat in. I'm still looking for a source of nut and bolt hose clips of the correct size, alternatively you can fit jubilee clips. The push rod also requires modifying which I can do for you or you can DIY. The cylinders come with a smaller reservoir and you'll need to get a piece of supply hose as the supplied hose will disintegrate after a short time. I have three with boots done in stock should any K Kronies require a replacement.
