1Back to top Go down   Hello from Ohio Empty Hello from Ohio Thu May 25, 2023 3:55 pm
celhardt
celhardt
Have had my '85 K100RT for several years.  It generally runs too hot for Texas so I hauled it to the summer digs in Ohio.
It did not wake up from the winter very well and I'm still trying to troubleshoot.
2Back to top Go down   Hello from Ohio Empty Re: Hello from Ohio Thu May 25, 2023 4:27 pm
Bricklayer
Bricklayer
Hello from Ohio 177912 Hello from Ohio 177912 Hello from Ohio 177912 Hello from Ohio 177912
https://anthonymrugacz.net/
3Back to top Go down   Hello from Ohio Empty Re: Hello from Ohio Thu May 25, 2023 4:59 pm
fishboy316
fishboy316
Hello and welcome!
4Back to top Go down   Hello from Ohio Empty Re: Hello from Ohio Thu May 25, 2023 6:24 pm
Bricklayer wrote:Howdy, I moved to NEO also with a TX K100. I recommend an AGM battery and appropriate charger designed for AGMs, staying away from gasoline with alcohol, and an annual use of Seafoam (best price at Marc's)  added to the fuel tank. Use up that Seafoam laced fuel before doing an oil change. If the bike sits and the piston rings get dry, try spraying a mist of motor oil into the spark plug holes to make starting easier.
P.S. Do you have the original ignition coils from '85. They have a tendency to malfunction, mine worked until warm then went haywire. Test the coils... saves a lot of frustration.
Welcome from Western New York!
Excellent advice above.
5Back to top Go down   Hello from Ohio Empty Re: Hello from Ohio Thu May 25, 2023 8:12 pm
bad boy
bad boy
hello celhardt
Cheerz, David
Hello from Ohio 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
6Back to top Go down   Hello from Ohio Empty Re: Hello from Ohio Thu May 25, 2023 10:55 pm
7Back to top Go down   Hello from Ohio Empty Re: Hello from Ohio Fri May 26, 2023 10:14 am
Bernie_K100
Bernie_K100
Hi,
Hello from Ohio 177912 to this forum!
Bernie
