1Back to top Go down   1987 bmw K75S won’t start Empty 1987 bmw K75S won’t start Fri Apr 14, 2023 3:12 pm
Asher123
Asher123
Hello, I have a 1987 bmw K75S, it was running last week but after coming back from a ride down the road, it wouldn’t start up again, pressing the start button and it won’t make a noise. The battery is charged, kill switch of off, side stand is up, clutch is in, tranny is in neutral, the lights come on when the Ignition switch is on, the blinkers high beam and horn work as well. I tested the starter relay and it works, same with the fuel pump, it works. It doesn’t crank when the start button is pressed, BUT just a few days ago it worked fine.
2Back to top Go down   1987 bmw K75S won’t start Empty Re: 1987 bmw K75S won’t start Fri Apr 14, 2023 4:46 pm
Two Questions:
1.  How many miles?
2.  When was the last time you checked the brushes in the starter motor and cleaned the commutator?
Bonus Questions:
Is the ground wire to the side of the transmission tight?
Are the connections on the starter motor tight?
3Back to top Go down   1987 bmw K75S won’t start Empty Re: 1987 bmw K75S won’t start Fri Apr 14, 2023 5:27 pm
Asher123 wrote: BUT just a few days ago it worked fine.
A close variation of that theme comes up in hospital ICUs and emergency rooms everywhere and often. Smile
Your K75S doesn't have a side stand switch so it doesn't matter if your moto's side stand is up or down. I'm interested in how you tested the starter relay and the fuel pump, and but mainly I wonder whether you've checked for power into and out of the starter button.
4Back to top Go down   1987 bmw K75S won’t start Empty No go Fri Apr 14, 2023 7:08 pm
daveyson
daveyson
I guess the starter has good earth through its mounting bolts, but you could check for that.
I guess the starter is getting power. With the start button pressed, you should have 12volts at the starter terminal.
If the starter is getting earth and power, but it's not turning, it's the starter.
 ~120,000 km
5Back to top Go down   1987 bmw K75S won’t start Empty Re: 1987 bmw K75S won’t start Tue Apr 18, 2023 11:41 am
Asher123 wrote:Hello, I have a 1987 bmw K75S, it was running last week but after coming back from a ride down the road, it wouldn’t start up again, pressing the start button and it won’t make a noise. The battery is charged, kill switch of off, side stand is up, clutch is in, tranny is in neutral, the lights come on when the Ignition switch is on, the blinkers high beam and horn work as well. I tested the starter relay and it works, same with the fuel pump, it works. It doesn’t crank when the start button is pressed, BUT just a few days ago it worked fine.
Please read the forum rules before posting a question. This is the Member's Intro section. This thread should be in Troubleshooting.
6Back to top Go down   1987 bmw K75S won’t start Empty Re: 1987 bmw K75S won’t start Sun Apr 23, 2023 9:23 am
Bernie_K100
Bernie_K100
Hi,
1987 bmw K75S won’t start 177912 to this forum!
Bernie
7Back to top Go down   1987 bmw K75S won’t start Empty Re: 1987 bmw K75S won’t start Sat Apr 29, 2023 8:10 pm
Paddy1
Paddy1
Welcome… first try simple push to start button and be sure on/off kill switch is in the correct position. I know sounds… but
Riding Beemers since 1988
1986 K100RT, 1985 K100RS,
2001 K1200LT, 2004 R1100S,
2004 R1150, 1980 R65,
2014 Zero FX, 2021 Zero SR/F
8Back to top Go down   1987 bmw K75S won’t start Empty Re: 1987 bmw K75S won’t start Sun Apr 30, 2023 5:20 pm
Paddy1
Paddy1
Oops! I’m bad, just re read original post.1987 bmw K75S won’t start 652573
