1 1987 bmw K75S won’t start Fri Apr 14, 2023 3:12 pm
Asher123
Hello, I have a 1987 bmw K75S, it was running last week but after coming back from a ride down the road, it wouldn’t start up again, pressing the start button and it won’t make a noise. The battery is charged, kill switch of off, side stand is up, clutch is in, tranny is in neutral, the lights come on when the Ignition switch is on, the blinkers high beam and horn work as well. I tested the starter relay and it works, same with the fuel pump, it works. It doesn’t crank when the start button is pressed, BUT just a few days ago it worked fine.
