1 Starter relay gone.. twice Sat Apr 08, 2023 4:28 pm
Gast1y
Hello,
I hope you are having a great holiday.
So was I with my beloved k100 and this happened. First occasion with this issue was straight after winter where I had a short somewhere and my starter kept turning without the key/emergency switch turned off. Battery went dead and the starter stopped turning. I thought perhaps the low voltage battery caused it, so I charged it. As soon as I added my ground to the frame, sparks everywhere. Starter kept turning and the starter relay was blown.
I replaced it, it was all good for 700km and two days. This time I got my bike fired up, noticed no lights. Thought I will turn off and on the bike. Starter kept turning again.... I could still ride, no problem but lights went off and could not do any turn signals what so ever. It went glitching out, as in, I would use the right signal and both would come on and not in a constant pace. Faster, slower, both, then just left etc. Crazy. only way to stop it is to disconnect the battery, when I plug the ground back in, sparks everywhere.. fireworks haha..
Previously, when first encountered this starter issue, I did not check if my lights were going crazy the first time, it was just a melted starter relay. I replaced it, then it was all good.. for 700km and two days again..
Any troubleshooting tips? Noticed my low beams never worked. Could that be the case, I doubt it..
