1 here we go again! Thu Apr 06, 2023 1:58 pm
fishboy316
Well I enjoyed the teardown and rebuild so much I think I will do it again! About 150 miles after finishing up it has started to leak oil again. Didn't notice until I left it on the side stand for about an hour. Came back and saw a drop on the pavement. It is definitely engine oil. The RMS I installed was a Teflon aftermarket from EME. Which rms do you folks recommend? Not sure what I screwed up yet but guess I will be at it again. Still riding it some but will be tearing it apart the end of the month. on the bright side it is as clean as a pin and running smoother than it ever has for me. Bought a set of vacuum gauges and balanced the throttle bodies. Replaced the 2 vacuum caps and checked hoses. She just laid down with as smooth an idle as you can imagine. Power is up and it makes me smile!
The cool thing is I am not afraid of doing it this time.
